1995 4Runner 3.0 vze engine from hell!!! help
Old 11-17-2007, 01:06 PM
lonewolve's Avatar
HI guys. i have 1995 TOYOTA 4RUNNER with 192,000 miles on it. I bought it with 120,000. It had a shift problem when i bought it, replaced temp sensor twice,flushed transmission ,had a oxygen sensor code I replaced it also.Finally hooked it up to a Snap-On MT2500,saw temp was fluctuating when wire to temp sensor was touched.Hunted down the wire found a lame attempt to splice with solder. I clipped out the bad splice stripped the ends put a heat shrink wire crimp connector that fixed it,several months later distributor went i replced that ,also a coil,total tuneup when i bought the 4RUNNER (plugs,cap,rotor,fuel filter,lube,oil,filter)recently i replaced the driveshaft it was ou of balance an couldnt be repaired.I have done oil changes every including oil filter every 3,000 miles since i bought it,sometimes i changed oil& filter every 2500 miles.
The day before a trip to Maine ,went out an checked all fluids for the trip and started the 4Runner up and ou of nowhere i had a really bad knock.Wound up renting a jeep commander to go on the trip.
When i got back i took my 4RUNNER to a local Toyota yard that does service work.Well that was a month ago and still i am waiting for my 4RUNNER,They have tried two separate engines and both have been bad. If i only knew more about engine replacement and wiring diagrams and had a lil more money at the moment id definitely do a 3.4 swap.I have already spoken to Andy Zook who lives near me in Lancaster, Pa.I love my 4RUNNER and just want to get back on the darn road.GRRRRRRRRRRRRRRRR.
Thanx for listening to mw whine
Rick
Old 11-17-2007, 01:22 PM
kylextrisler's Avatar
hahah im jk
im sorry to hear about your problems,
i know what its like when you think your getting your truck fixed then something else comes up
it never ends sometimes
the 3.4l swap is popular you can def. do alot of searching and lot of learning
thats how i did my lift, and did my engine work
just keep lookin around might be able to do it yourself!
i personally wanna do the 2JZ-GTE swap
but that is just a dream =D
Old 11-17-2007, 02:16 PM
Paul H.'s Avatar
So what is actually wrong with your runner? And why are they putting bad motors in it? I would be asking some serious questions if it was mine.
Old 11-17-2007, 05:40 PM
RobD's Avatar
The 3.4 swap is definitely worth it. I did mine with zero knowledge about swaps before and Andy was a hell of a nice guy and a whole lotta help. It makes the Runner...uh...funner...
Forget that last part.
Old 11-20-2007, 03:44 PM
lonewolve's Avatar
my 4runner is killin my morale
I didnt have much$$$$$$$$$$$ when i got back from vacation, so i chose to replace the engine i had with a used engine from a yard till i could do the 3.4 swap,i love my 4runner and body and frame as well as mechanically i have been on top of maintence religiously,so i dont want to scrap her.its been a month since i last had her and i just want to get back to driving her is all.besides its almost deer season and she goes where i need her to get.
Thanx for listening
Rick
lonewolve's Avatar
Thanx for listening
Rick
Old 06-04-2014, 01:49 PM
hindustan13's Avatar
Hi,
can anyone tell me authoritatively if a '94 engine will go easily into a '95?
Old 06-04-2014, 01:50 PM
4runner that is
Old 07-13-2014, 08:21 AM
KingsShadow's Avatar
Engines are the same. Some electrical connectors are different a 94 engine should drop right in and bolt right up no problem. As for the knocking sounds like a rod bearing got destroyed. Used motors are a bit sketchy, because you dont have a history in that engine. Definitely do the 3.4 swap when you have the money, if thats the option you want to persue. I have a 3.0 in mine and it still does great.
Old 07-13-2014, 09:37 AM
dromomaniac's Avatar
Rick
I don't know if I'd trust guys that manage to put in two different bad engines. Seems like a waste of their time as much as yours.
For your information, a shop called Offroad Solutions sells a complete harness for the 3.4 swap: http://www.offroadsolutions.com/prod...ing-harnesses/
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
ZONAYODA
06-30-2015 05:36 PM
yamaha73
06-18-2015 06:19 PM
ra72
06-16-2015 11:10 AM
95Runner
06-09-2002 09:08 AM
Quick Reply: 1995 4Runner 3.0 vze engine from hell!!! help
