1994 toyota pickup dlx transmission shifts hard while cold.
I have 1994 toyota pickup dlx 4wd auto trans. the transmisson shift hard into first and second while cold. when reaches operating temp shifts fine. I changed the At filter kit no changes. any advice?
Check the throttle cable. http://personal.utulsa.edu/~nathan-b...32prelimin.pdf On the A340H, the throttle cable does not set shift points (that's electronic), but how "hard" it shifts. As in, your problem.
thanks for link and reply but wouldn't it shift hard all time if it was throttle cable? it only shifts hard into 1st while cold and sometimes 1st-2nd while cold. when get operating temp shifts perfect.
I don't know. But if you check the throttle cable and it's set incorrectly, fix it. If that doesn't make the problem go away, then continue with your diagnosis.
Here's the page with general diagnosis http://personal.utulsa.edu/~nathan-b...30generalt.pdf (listing throttle cable as the first thing to check under "harsh shifting.") The other items are well beyond my personal comfort zone.
Its probably a loose clutchpack that slips until it gets warm....when its cold it slips a little right as it shifts and bangs in gear. When warmed up the packs expand enough to not slip. Talk to a tranny shop about a friction modifier additive. May help.
Could also be a sticky solenoid that doesnt like the cold.
Does it seems to rev a little as it shifts and then clunk into second? dddddwaaaappow.
Never found cause of problem. My suggestion let truck warm up 5 mins or so before driving. I've found that to help some. Also added lucas transmisson additive. but warm that stuff up bc its like goo if not hot.
Thanks for the reply. I checked throttle cable and found it a little long, adjusted but no help, seems that's the fix when trans shifts hard in all gears. The next steps in FSM are beyond me so I might have to pay out some $$$.
took mine to transmisson shop they told me that seals and rings could be bad and needed be rebuilt $500 in parts and $1500 labor. not gonna happen found At rebuild kit on Autozone.com for $269.99
Hard shifts are generally caused by high line pressure, or a bad accumulator. Your torque converter may be going bad, but I don't think that it is causing your hard shifts.
The fact that yours shifts hard only in 1-2 makes me suspect the valve body.
Does it shift hard on the downshift as well? Does it shift hard from N to D?
had the filter and fluid changed out. Think it maybe sifting worse. Everyone is saying worn out tranny, probably from no service from previous owners. Lloks likr it will be 3 thousand dollars
6th Gear
19
12-10-2019 07:31 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
