1994 4runner no start
Old 01-18-2011, 05:07 PM
RMA
RMA's Avatar
Originally Posted by cjsgarage
hmmm. I put another cold start injector in it, but I have not pulled it out to check. So far, in my endless hours of testing, I haven't found anything that'll make this baby not start-- EXCEPT that it has weak injector pulse and weak crankshaft/camshaft signal. But like I said, I have tried distributor after distributor and no avail. I just checked the wiring from distributor to the computer and it's a-okay. I've got my buddy coming over with a computer as we speak, and we'll see if that gets her going... but somehow, I doubt it.....
if everything is as you say , then i would try another ecu next .
Old 01-19-2011, 01:39 PM
cjsgarage's Avatar
RMA: of course not. computer didn't do squat and my buddy's truck started just fine with this 4Runner's computer in it. No dice.
Old 01-19-2011, 01:42 PM
cjsgarage's Avatar
Originally Posted by joesands
Would you believe I am having the EXACT same problem on my 93 hilux? I replaced head gaskets and re-assembled, she started right up and drove it about 5 miles home from my buddies shop. It ran ok but I knew the plugs were fouled out from the head gasket. Tried to start next morning and it just cranks, does not even try to start. Replaced plugs and still no start. I checked my timing and spark and fuel just like you have. All seems to be there but engine will not hit a lick...driving me insane!!!
yo brother. Like I said in the beginning of this thread, every Internal Combustion Engine needs three things to start: Fuel, Spark and Compression. Start there, in your case. I'd start with spark. Make sure your spark plug wires are sparking the plugs. Get a 5$ spark checker at your local harbor freight or auto parts house
Old 01-19-2011, 05:39 PM
joesands's Avatar
ok, my spark is good but today i discovered it is flooding like crazy. plenum is full of fuel, plugs are wet. blew plenum out with air and now it tries to start but the fuel just dumps into plenum. maybe, a vacuum line/fuel line crossed? geez...
Old 01-19-2011, 05:42 PM
  #25
dave_n_ky's Avatar
no start
mine did that no start thing and it turned out to be the relay on the under the hood fuse box. A big relay that i didnt check till after i broke a fuel line taking the tank off. Then i propped open the afm turned the key on and when i wiggled the relay, the fuel pump came on. And sprayed fuel all over the back seat but problem found. Make sure to check the relay there. Everything else was working fine.
Old 01-19-2011, 06:01 PM
  #26
joesands's Avatar
OK, Thanks but I found the problem just not sure how to correct. I unplugged the vacuum line from brake booster to right side of intake/plenum and also the line I have going to/ or from the fuel line coming out from under the plenum. truck starts but Im not sure of what lines go where. Fuel is blowing out line when running and Im not sure what line goes there...lol!!! Can you say dumbass!
Old 01-19-2011, 07:07 PM
  #27
joesands's Avatar
Truck starts and runs now after I unplugged vacumm line from brake booster to plenum, and fuel {return line]? from under plenum. But I need to know what lines go where because fuel is coming out of line under plenum and not sure where it should go....sorry didnt mean to repeat my posts...
Old 01-19-2011, 08:03 PM
  #28
justin_4runner's Avatar
heres some pics of the vacuum line areas hope this will help.
Old 01-19-2011, 10:31 PM
  #29
cjsgarage's Avatar
are you showing what's wrong or what you fixed? I guess, what I mean is, Did you fix it?
Old 01-20-2011, 11:48 AM
  #30
i was posting the vacuum hoses pics cause he said he had some that where not hooked up and not sure where they went.
Old 01-21-2011, 12:23 PM
  #31
cjsgarage's Avatar
An update!!!!
it fired two cylinders yesterday in the afternoon and then cranked after that. It was after I pinned the throttle plate open for several hours (let the fuel evaporate out of the intake) and unplugged the cold start injector. no luck getting it to fire since, but I have narrowed it down to fuel mixture. any help?
Old 01-21-2011, 05:21 PM
  #32
joesands's Avatar
Got mine going and drove it to work today. I think the cold start injector is sticking and flooding it out. I unplugged the connector to it and it starts now. Not 100% sure thats it, but I at least have it going...I will update if I find something else..And thanks for the pics and info Justin 4 runner!
Old 01-21-2011, 06:28 PM
  #33
sam333's Avatar
Joesands ,I dont have a 3.0 and am to lazy( to much beer) right now to look it up, but is it your fuel pressure regulator that you unplugged? You need a manual.
Old 01-21-2011, 09:29 PM
  #34
sam333's Avatar
Is the vacuum line you disconnected from a VSV (valve) on the passenger side of the engine bay to your fuel pressure regulator? and is that where the fuel is now leaking from?
If it is, then you have a bad fuel regulator, that would also cause your flooding problem. Hook the brake booster line back up and check your fuel pressure regulator.
Old 01-22-2011, 11:27 PM
  #35
cjsgarage's Avatar
sam, are you suggesting that for joe or for me?
Old 01-22-2011, 11:31 PM
  #36
sam333's Avatar
Truthfully, I got the posts mixed up( to much beer).
Old 01-22-2011, 11:36 PM
  #37
sam333's Avatar
Did you get it running?
Old 01-22-2011, 11:37 PM
  #38
cjsgarage's Avatar
no problems! Have any ideas for me, though?
Old 01-22-2011, 11:40 PM
  #39
sam333's Avatar
Whats it doing now? You said you thought the pulley slipped? Did you work that out ? and you thought it was a mixture problem ( to much fuel)?
Old 01-22-2011, 11:51 PM
  #40
cjsgarage's Avatar
Sam.
Yeah I got the balancer all fixed, and the distributor is all good. So I have it down to fuel mixture. I believe it to be too rich. It tried to start when I left it overnight with the throttle body open to help it air out.
Quick Reply: 1994 4runner no start
