1994 4Runner 3.0 V6 not getting fuel
Hello please help there is a blizzard showing up tonight!! My 1994 4Runner ran great last night went to leave to go to waork today and she wont start just ranks and cranks. I sprayed some starting fluid into intake and she fired right up and ran for 5 secs. I think I am not getting fuel I dont hear a pump click or anything? I really dont want to change my fuel pump yet anyone give me some quick troubleshooting tips? Its is weird it has allways ran great and just nothing today.
If you really want to test for fuel flow, you can remove the fuel return line at the fuel pressure regulator, and put it into a suitable container. If there's pressure in the rail fuel will gush out. You can then put it back; it's a low pressure line and so just uses hose clamps.
But if nothing comes out, you still don't know where to look. So do it the easy way. With key-on, engine off, jumper fp to B+ on the diagnostic connector. You should hear the fuel pump come on. Now try to start it. If it starts and runs, then you have a problem in the COR / VAF circuit. (which is where I'd put my bet)
Huh? No fuel line screws into the plenum. There is the line that goes to the cold start injector; you don't want to disconnect that because the crush washers are one-time use. Think you can get away with reusing them? We're talking about pressurized gasoline.
You were right on thanks man she kicked fuel pump on and fired right up with jumper wire installed. I guess I can just drive like this for now until I can figure out what actually needs to be replaced. thanks for the advice on the jumper wire saved me a lot of headache I was not looking forward to a fuel pump change.
nvwiggins
13
06-16-2016 03:05 PM
EatChipsNow
09-09-2015 01:25 AM
