1992 Toyota Pickup - Failed Emissions
Old 03-20-2012, 06:52 AM
Troy69's Avatar
Hey guys. I have a 1992 pickup truck I just bought. I took it last week to emissions to get my tags. The car failed due to High Carbon. The first time it failed by 10 points but the RPM was 2500, the second time I tested it failed by 950. The idle was set really high so I adjusted it to factory settings which is 870 RPM I dont know what to do please help.
What do you guys recommend..
Old 03-20-2012, 07:58 AM
93toyrunner2's Avatar
Failed Emissions
Post your numbers.
When was your last tune up? Air filter? Basics? Did you drive the truck around to get it hot, at least 20-30 minutes?
SeaFoam intake cleaning as well as in the gas - worked for me. I added 1 can of SeaFoam to the tank (1 oz per gallon), filled it up with Chevron Premium, and drove it until it was near empty. Prior to the test, I took it out on the interstate for 30 minutes, and then directly to the test facility.
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
ChrisJ
30
11-29-2009 11:13 AM
Quick Reply: 1992 Toyota Pickup - Failed Emissions
