1990 Pickup DLX to SR5 Frame up body swap (pics included)
Old 11-30-2009, 03:36 AM
  #61
HAI-TEK7's Avatar
Originally Posted by tooslim1108
what you doing with the old cab and bed
Sold the bed, you can have the cab if you want it.
Originally Posted by MaK92-4RnR
Wait, so what's the process of dying all this stuff? what'd ya use and where'd ya get it?
Prep the crap out of them and paint/dye. i used SEM Color coat, purchased at my local auto paint store. You can find them cheaper here http://www.toolsource.com/color-coat...k-p-59023.html
Originally Posted by Blue Bowtie
Lookin really good man.
Thanks.
Old 11-30-2009, 04:14 AM
  #62
shaeff's Avatar
Looks fantastic dude!
Old 11-30-2009, 06:11 AM
  #63
X88&94GT's Avatar
Wow, nice job!
Old 11-30-2009, 06:45 AM
  #64
slacker's Avatar
yeah , great work!!
Very nice
Old 11-30-2009, 07:38 AM
  #65
jrobertson4runnner's Avatar
what did you use to get the stickers off? and was there any difference in color under the stickers versus otherwise?
Old 11-30-2009, 08:50 AM
  #66
HAI-TEK7's Avatar
Heat gun, plastic razor blade, 3m adhesive remover and alot of elbow grease. The paint is alittle shinier underneath, but a good wash and wax it wont be noticable.
Old 12-06-2009, 04:51 PM
  #67
MaK92-4RnR's Avatar
is there any update to this?
Old 12-07-2009, 12:23 PM
  #68
HAI-TEK7's Avatar
Not too much, been driving everyday, runs just as good as it did before.
I will update more of the interior, but not anytime soon. Getting cold up here.
Old 12-08-2009, 04:35 PM
  #69
MaK92-4RnR's Avatar
how is the black paint holding up on your dash and such? Im thinking about doing the same thing. Would you suggest using the same method or would you do things different? what kind of prep did you do? did you just dye it or primer / paint method?
Old 12-11-2009, 10:38 AM
  #70
HAI-TEK7's Avatar
Interior is holding up great so far. I had the dash apart a few times trouble shooting some wiring, and it still good to go. Steering wheel so far show no sign of wear.
I didnt primer, since i was on a time crunch. The only thing i would do different is, better prep/primer. I would get some of SEM Sand Free prep for the hard plastic. It actually softens the the plastic, so the dye would adhere better. I dont have any problems with it now, but gives you piece of mind. I would have picked it up if the paint store i went to had it. I also would use their vinyl prep/primer too for the dash, again piece of mind, and if the store had it, i would have gotten it.
So far its been holding, I got a few scuffs on the glove box from my GF heels, but i took a damp paper towel and it cleaned right up.
Hope this helps, here some tips from their site: http://semproducts.com/images/Users/...RAP-1_1009.pdf
-Hai
Old 12-11-2009, 11:07 AM
  #71
yoder519's Avatar
wow man thats a great job. am the only one that likes the red interior? its a love hate kinda thing. you cant "kinda" like red interior. i would just leave it like it is with teh black dash, red everything else. its somethin you dont see everyday
Old 12-11-2009, 11:37 AM
  #72
HAI-TEK7's Avatar
Thanks. Honestly, i really didnt mind the red, but im loving the black.
Old 02-28-2012, 09:03 AM
  #73
HAI-TEK7's Avatar
Thought I would give this an update. The black interior paint/dye is holding up awesome. It looks just as good as it did when i painted it. The only wear is the steering wheel, it is starting to chip a little. Its only chipping because when i climb into my truck, i'm holding my keys in my hand and grabbing the wheel to pull myself in; hence the keys digging into the paint. Plus my steering wheel is worn so its pretty smooth, but hell it lasted for this long.
Old 02-28-2012, 11:48 AM
  #74
DetroitStyle's Avatar
Did you ever do anything with the carpet/seats? I've seen people dye their carpet black and it looks pretty good.
I've got a baby blue interior in my 4Runner and I'm thinking about dying it black.
Old 02-28-2012, 12:07 PM
  #75
Crazy Hakachukai's Avatar
That's pretty awsome! How much does the cab and bed weigh?
I'm considering how difficuilt it would be to do it to my 81
Old 02-28-2012, 06:50 PM
  #76
drmix's Avatar
Yeah any finished pics? It would be nice to see how all the interior turned out
Old 06-20-2020, 10:01 PM
  #77
83yotanowoj's Avatar
On your harness did you end up keeping the 3.0 body harness?
Got some more done today. Since the new cab is a v6 i found some differences. The fuse box to fuse panel (kick panel) harness is different. So i had to swap that out. Luckily the passenger side harness unplugged from the fuse block, so i didnt have to swap the dash harness also. That would have sucked.
Here the 2 harnesses side by side. 22re on left, 3.0 on right. The battery cables were cut on the v6 harness.
22re on bottom
Heres the 2 black plugs that i un plugged from the block. Hopefully the rest of the dash harness is the same.
Does anybody know what these 2 plugs are for? i know that go to 2 vacuum solenoids, but what are they for? Any help will be appreciated. These 2 plugs are the only differences i seen so far. There are located right by the fuse block passenger side.
Here my engine with all teh accessories bundled up, ready for cab to be lifted.
I still have brake lines and fuel lines to disconnect, the we can have lift off.
did you manage to connect the body harness from the 3.0 to the 22re engine harness? In the process of doing the same thing just with a 4runner instead
Old 06-21-2020, 06:47 AM
  #78
drmix's Avatar
I believe those are the connectors for the ADD vacuum valves.
http://www.ebay.com/itm/89-90-91-92-...-/302933146706
6th Gear
19
12-10-2019 07:31 AM
bradstyle
06-19-2018 03:15 AM
greenbuggy
06-28-2015 10:40 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
dirtrider0129
10
06-24-2015 12:24 PM
Quick Reply: 1990 Pickup DLX to SR5 Frame up body swap (pics included)
