1990 4Runner v6 wont start when warm
Old 09-27-2016, 04:10 PM
1990YotaRig's Avatar
I am having some problems troubleshooting this issue. ill drive the truck anywhere from 10 min or more and when i turn it off and leave it for about 10-15 min and then try to start it again, it will idle at about 500 rpm for half a second and then die, and then will just crank like a champ but wont start. I have to let it sit upwards of 2 hours at least before it starts again, sometimes have to let it sit over night. i just did the fuel pump, fuel filter, injectors, fuel pressure reg, intake manifold vacuum lines, cleaned mass airflow sensor. at first i thought it was flooding but i checked the plugs and they were dry as a bone. I am still researching but any ideas or help on what could be causing this would be awesome!! its all happening on a 1990 4Runner, 3.0 . thanks!
Old 09-27-2016, 04:59 PM
mholme's Avatar
Can you hear the fuel pump when in a no start condition? You can jump FP and B+ in the diagnostic port to run the pump constant, bypassing the other components and see if it starts. Might also check the fuel pressure up system. Search FPU VSV.
Old 09-27-2016, 06:09 PM
hard to tell if the pump is going with the engine cranking, but i don't hear it prime when i give ignition power. ill get some help listening for it tomorrow. Ok cool, ill run a pressure test tomorrow as
well and get back! where would i search FPU and VSV? Thanks!
nuknuk
12-11-2016 08:13 AM
Jakeypig1
08-19-2016 02:44 PM
Luther
08-06-2016 03:11 PM
Quick Reply: 1990 4Runner v6 wont start when warm
