1989 22r - Bizarre cooling issue.
Old 07-04-2013, 09:01 AM
Turd Furgeson's Avatar
If you plan on keeping this truck for a long time,don't bother with a cheap aftermarket radiator. Take yours to a radiator repair shop and have them test it to make sure your tanks are in good shape (not cracked all over). Then have them re-core it with a high quality core (I like pacific's cores out of canada) and make sure they don't skimp on the solder (make sure they fill all solder joints completely and block off end rows of tubes).
Old 07-04-2013, 08:15 PM
z31freakify's Avatar
just put a long funnel on the where the rad cap goes fill with water/antifreze, let it warm up with heater all the way up to temp and start squeezing every coolant hose, untill you don't see no more bubbles coming out of the coolant from the funnel, put rad cap back on your done.
Old 07-08-2013, 06:00 PM
Triple's Avatar
Too late, already replaced it with an $80 piece from Rockauto. Wouldn't have mattered anyway, because the one I took out was a cheapo unit with plastic tanks, too.
I only put about 3,000 miles on the truck per year, so I'm not too worried.
84'22r
02-13-2019 05:35 AM
TACOJO
11-27-2015 05:26 PM
Jcrawl94
10
10-24-2015 04:34 PM
corey519
08-12-2015 11:12 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Quick Reply: 1989 22r - Bizarre cooling issue.
