1988 Toyota SR5
Old 09-24-2012, 02:40 PM
Toyotabob's Avatar
1988 Toyota SR5
1988 Toyota SR5, 22RE EFI. help, at witts end.. Truck had been sitting since 1998. Rebuilt motor, new fuel pump and cleaned tank. Started and ran for about 15 minutes, died and hasnt started since. I replaced the following; plugs, wires, distributor cap, rotor, distributor magnetic coil, coil & igniter, ECU. I have no trouble codes, I have spark and fuel pressure but no injector pulse when tested with NOID meter. Will not start with ether. any other ideas. Also new fuel pump and filter, All grounding is verified correct. What else can i check?
Old 09-24-2012, 03:21 PM
Motox711's Avatar
What is the P/N of the ECU you put in. if you replaced it i would check that first. then the AFM. one other thing you can do is check if the wiring is corroded in the harness. I experienced this first hand and it took me a bit to figure it out. there is some connections within the harness that will eventually corrode and break. if you see my build thread there is a good example of the corroded wires.
Old 09-24-2012, 03:32 PM
donomite49's Avatar
timing chain???
compression check?
if so maybe injectors stuck/clogged with varnish.
gotta be something.
gotta be a reason.
@ mx711 i ride too AND my 95 integra has 264k. lol.
Old 09-24-2012, 03:35 PM
Motox711's Avatar
@ mx711 i ride too AND my 95 integra has 264k. lol.[/quote]
Awesome- i live to ride. I should update my info my integra is at 267k now.
Old 09-24-2012, 03:49 PM
donomite49's Avatar
ha ha my teg is chasing after yours...
ride on, on two and four wheels...
Old 09-24-2012, 05:14 PM
Toyotabob's Avatar
teeth missing on dizzy gear on distributor shaft
I think i found why my truck wont start.1988 Toyota SR5 22RE efi, found 4 teeth missing on gear, on completly. Is that why? Did the pieces most likely fall into the pan? Can i assume the gear it meshes with is still good? Any help would be appreciated.
Old 09-24-2012, 06:04 PM
donomite49's Avatar
if it was me i think i would go ahead and do the timing chain, water pump etc.
and pull the pan to find the missing metal.
at the very least you need to pull the pan and find ALL the missing metal that is loose in the engine.
you also need to find out why the gears stipped,.
did the dizzy lockup or what?
good luck!
Old 09-27-2012, 06:30 PM
kornhuskerwizard's Avatar
yeh where did the missing teeth go? might as well pull the engine it would be easier to work with.
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
Cplmike
07-08-2015 08:47 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 1988 Toyota SR5
