1988 4 runner that needs help please
Old 09-26-2007, 03:32 PM
pat24's Avatar
my truck wont start so the first thing i did was pull the cel codes by jumping the ports i just want to know if these things are dead will it cause the truck not to start i got 3 problems
1. THROTTLE POSITION SENSOR SIGNAL--OPEN OR SHORT IN TPS SIGNAL
2.IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
3.INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
please help me the codes again are 24, 41,51 thanks if any one can help it would be great
Old 09-26-2011, 05:26 PM
86carbPU's Avatar
I got the same code 51 on 88pickup too. I ended up finding out that the IDL-E2 within the TPS wasn't working. I've still to find out what caused it to fail but I'll try to trace the wires back to the ECU & do a voltage check & post the results, if it helps.
Here's the resources I've been using for the TPS:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
http://personal.utulsa.edu/~nathan-b...e/102engin.pdf
http://www.autoshop101.com/forms/h33.pdf
You can get the Factory Service Manual @:
http://ncttora.com/fsm/index.html
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 1988 4 runner that needs help please
