1987 toyota pickup efi swap
Old 03-10-2013, 05:43 PM
justin miles's Avatar
need some info on how to swap from carb(1987) to efi on 22r engine got a 1992 toyota complete with blown engine want to swap to the 1987 i have need time and steps and all the parts i will need off the truck and any extra info would be nice
Old 03-10-2013, 09:04 PM
Co_94_PU's Avatar
Computer, engine harness and everything they're attached to. You'll also need both manuals, I'm pretty sure you need to move some pins around at the junction blocks behind the computer to get all the dash stuff working.
Also there is a whole forum section here for engine swaps, might be a good idea to check over there.
"site:yotatech.com 22r to 22re ("conversion" or "engine swap")"
Old 03-10-2013, 10:27 PM
wyoming9's Avatar
Red face
You also need the fuel pump and the fuel filter for the FI as well as the correct fuel line and clamps where you use rubber line.
Old 03-11-2013, 06:12 AM
Okay I have all that stuff how hard is the wiring , can I keep all the wiring inside the cab only thing I want to change is the speedometers the 1994 has a tachometer
Old 03-11-2013, 06:27 AM
85TurboRunner's Avatar
The speedo from the 94 is different then the 87 youll have to get creative to make it fit.
Old 03-11-2013, 09:29 AM
brianh699's Avatar
X2^ if the 94 has an electronic speedo which I'm pretty sure it does, your 87 uses a cable speedo.
arlindsay1992
01-23-2024 01:34 PM
91toybeater
12-27-2015 07:46 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 1987 toyota pickup efi swap
