1986 4runner radiator replacement
Old 11-09-2022, 07:56 AM
Happy Gilmore's Avatar
Question 1986 4runner radiator replacement
Hello all, not sure if this has been posted before but I figured I'd ask here!
Just bought a new radiator for my automatic 86runner, but the radiator says its for a manual transmission. Will it work fine?
This is the radiator I bought:
https://www.carparts.com/details/Toy...1986/P945.html
Thanks!
Old 11-09-2022, 10:19 AM
Diesel pickup's Avatar
The manual transmission radiator likely won't have the transmission cooler circuit on the bottom. However, it is possible that they simply sell the same radiator for both applications, so take a look at your new rad and if it's got the transmission cooler fittings on the bottom then you're good to go.
Old 11-09-2022, 02:46 PM
wallytoo's Avatar
why not install it and find out? the linked one appears to have the transmission cooler line fittings at the bottom tank. does the actual one you received have the two fittings?
jska
03-07-2021 07:35 PM
branz1029
10-03-2013 11:22 AM
atom631
02-28-2013 04:22 PM
Memphis4X4
7
10-25-2002 04:27 PM
Quick Reply: 1986 4runner radiator replacement
