1986 22re rebuilt and now dead!!!!
Old 12-30-2011, 03:28 PM
Coacheeaton's Avatar
Ok, I'm quite a newb here but I've owned this 4runner for 20 years , I'm somewhat familiar with it but not to much, I recently had the head cavitate and cause the gasket to blow. I installed a new head, bolted up everything, set timing as close as I could initially and plugged up everything and put on new vac. lines. Put in a new battery and expected it to atleast turnover... IT DIDN'T. In fact all it did when I turned the ignition was turn on the fuel pump.
The lights all work and when I hit ignition they do not dim as if there were a major draw on the battery. So I checked the starter, its fine, I replaced the brushes with new ones anyway, still dead.
I can easily turn the engine over by ratchet on the crank pulley, so my question I suppose is...... what electrical gremlin do I have?
ONE NOTE HERE..... the truck did set for a year before I began the repair... and my lazy arse didnt drain the gas when i parked it so after the rebuild I drained it and installed a new fuel pump and filter just to avoid future problems.... could setting that long sieze up a relay somewhere?
Thanks in advance to anyone who answers!!!!!
Charlie
Old 12-30-2011, 03:52 PM
totally a bro
Staff
vital22re's Avatar
So your starter is not kicking on at all? make sure you get 12v to the signal wire at the starter. Could be the starter relay is stuck.
Old 12-30-2011, 04:05 PM
thanks bud, I didnt have a meter when this all began so I couldnt check that or anything else really, nor did I have a fsm, I just downloaded an electronic version and so I feel a little better equipped to tackle the gremlin... I'm comfortable with the mechanical stuff but engine electrical systems just baffel me!!!!! that and auto tranny's!!!!
I do know that the engine will turn over if I supply voltage directly to the starter, it won't even attempt to fire because " i don't know why" 8^) but the starter will crank the engine over like that. I'm relay hunting in the am I suppose!
Old 12-30-2011, 04:59 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Is the CEL illuminating when you turn the key to ignition? Not to the start position, but the ignition position. And, I don't mean flashing a code, either. The CEL is supposed to illuminate at the IG position letting you know power is getting to the ECM and the IG circuit is complete.
Old 12-30-2011, 06:33 PM
i will check for the cel in the morning, I haven't honestly looked that i can remember....
Colington
03-08-2020 09:51 AM
mskalmus
05-28-2017 07:51 AM
toofly1999
07-25-2015 07:09 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: 1986 22re rebuilt and now dead!!!!
