1986 22R California Vac issues
Old 08-20-2011, 11:09 AM
Madathlon's Avatar
OK I brought a 86 with the engine in the bed. After a full rebuild I installed it and it runs great, Issues is I have to now pass California smog, this is a California built smog ready truck and I still cant seems to get the vac lines right, I followed the Vac map but there still a few lines that seems to be missing. Does any one own a Ca smog set up and can I get a few photos of what it should look like.
The Diagrams are ok, but I seems to have more open vac tubes then the diagrams shows and I need to know if I am missing something some where.
Thanks for and help ahead of time.
Old 08-22-2011, 08:11 PM
Madathlon's Avatar
Come on, someone out there must also have a 86 PU with the 22R engine and California smog set up..
Old 08-23-2011, 06:21 AM
xylicon's Avatar
Woops missread, I read 22re.
Old 08-23-2011, 06:36 AM
xxxtreme22r's Avatar
Is this the vac diagram you are using?
Old 08-23-2011, 05:43 PM
Madathlon's Avatar
Yes that is the one. But I seem to have more vac lines and ports then the diagram shows and its hard to know what is the right ones at times, some are very close to each over.
Old 08-23-2011, 06:08 PM
drkblu4runner's Avatar
on my 3.slow there is a few plugs on the manifold. im guessing 22r may have a few too. you should post pics of what you got.
nanhodges2733
05-29-2020 03:28 PM
mskalmus
05-28-2017 07:51 AM
dumpster84
04-30-2016 06:03 AM
pyramid
07-30-2015 10:05 AM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: 1986 22R California Vac issues
