Valve lash settings
Old 02-18-2011, 05:19 PM
LSUfan71's Avatar
Originally Posted by xxxtreme22r
torque spec on the valve cover I think is 20 inch pounds according to the TTB article.
I knew it was in-lbs, not many of us shade tree mechs have a torque wrench in in-lbs...
Old 02-18-2011, 06:40 PM
xxxtreme22r's Avatar
IIRC when I did mine with an in-lb torque wrench it was about a half turn from finger tight with new grommets and a new valve cover gasket.
Old 03-27-2011, 07:13 PM
LSUfan71's Avatar
Will gas leaking in the vacuum system cause extra noise, such as I described? I noticed a drop of gas from the AAP tube at the BVSV. I believe the AAP diaphragm was leaking, it was dry/stiff too. I replaced the AAP diaphragm and the BVSV plus some new vacuum tube. Then reset the lash settings to .007 & .009, now it purs like a kitten
the1998sr5
15
07-14-2020 08:35 PM
88sasturbotoy
08-11-2015 01:56 AM
thefishguy77
07-30-2015 10:59 AM
voiddweller
07-15-2015 03:56 PM
cars-guy
07-11-2015 07:51 PM
Quick Reply: Valve lash settings
