Transmission Oil Recommendation - W56
Old 01-30-2012, 06:14 PM
redwolf3's Avatar
Holy dead thread revival batman!
As a note, I ran the manufacturer recommended fluid and have had no Ill Effects. I was having some stiff shifting issues before the rebuild when cold, but that must have just been due to the synchro's which were on their way out.
Old 02-16-2012, 11:52 PM
dspan's Avatar
i see
Old 02-16-2012, 11:55 PM
dspan's Avatar
Originally Posted by Subzero2cirb
85-140 + lucas oil stabilizer. Its thicker to help quite the trans and tcase down plus doesnt leak as easily and or let in water as well, I had an L45 and she was a GRowler put in 85-140 much quieter, then aded lucas even quieter and shifter smoother, no hard shifting ITS a toyota 4x4 trans for crying out loud not a maseratti these guys can use some thicker lube to help with the slack caused by abuse and high mileage. i also use it in my w56 now and even after my 4.7 install. the tcase even whines waay less with 85-140 and lucas now takes around 5-6 hours of solid wheeling to start whining at all.
Thanks for the tip, I am trying it this weekend. I have an H55F.
Old 02-17-2012, 06:38 AM
2003mikem's Avatar
RedLine MT90
Old 01-25-2013, 03:27 PM
  #25
Bullet22r's Avatar
i have a question about GL-5 gear oil whats wrong about using it? because my local auto parts store recommends it for my 1986 toyota 22r 4x4 pickup
Old 01-25-2013, 03:43 PM
  #26
rokblok's Avatar
It contains corrosive additives that can/will eat the brass synchros.
Old 01-25-2013, 04:41 PM
  #27
Mr.Utah's Avatar
It apparently corrodes yellow metals, like your synchros. Use the the gl-4 or some high grade stuff. Everyone will have their own opinion of course, but basic gl-4 cheap stuff works fine. I have been using Amsoil synthetic 75-90 gl-4, it has worked flawlessly from 0 deg to 110 deg/f. Its good stuff but pricey.
Old 01-26-2013, 08:46 AM
  #28
Bullet22r's Avatar
okay thanks for the info guys
smthwsn357
05-01-2024 07:28 AM
mskalmus
05-28-2017 07:51 AM
jjrbus
07-17-2015 07:06 AM
ryerye13
07-14-2015 08:27 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Transmission Oil Recommendation - W56
