timing chain
Old 10-03-2013, 04:21 PM
latis's Avatar
timing chain
What would cause a timing chain tensioner not to work, I have taken the cover off and everything is in place but when I start the engine the chain is hitting the cover. It`s a 1981 22R
Old 10-03-2013, 05:21 PM
rokblok's Avatar
Oil pressure? Chain stretched so tensioner is maxed? Guides broken?
I'm not positive if there is a spring assist in the 22R tensioner, if so, possibly failed spring.
Old 10-03-2013, 05:48 PM
latis's Avatar
How does the oil get to the tensioner, and can the oil pump be bad
Old 10-03-2013, 05:55 PM
Kiroshu's Avatar
Chain hitting the cover...?
If its hitting the inside of the cover then you have damaged/missing timing chain guides(dampers).
The chain tensioner is an oil assisted spring tensioner.
Low oil pressure can cause timing chain tensioner to be inoperable/faulty.
Low engine oil level.
Incorrect engine oil weight.
Oil gallery passage blockage to timing chain tensioner.
Failed oil pump.
Incorrect timing chain tensioner.
Timing chain worn beyond service life.
Internal engine damage.
Old 10-03-2013, 05:58 PM
Kiroshu's Avatar
Old 10-04-2013, 07:24 AM
Gizler00's Avatar
Im going with the rest of the guys here and saying that a guide has to be broken if its hitting the case.
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
razorman8669
07-12-2015 12:13 PM
Quick Reply: timing chain
