Solenoid resistor heat?
Old 08-27-2013, 03:31 PM
Guyechka's Avatar
Just how hot does the thing get? Is it safe to run wiring touching it?
Old 08-27-2013, 10:06 PM
slow-mo's Avatar
Well, I'll be the first to ask, what are you talking about?
The starter solenoid?
The fan blower resistor?
I have not heard of a "solenoid resistor", unless it is specific to your 4Runner(s), or the EFI system.
Old 08-27-2013, 11:29 PM
wyoming9's Avatar
Red face
I think they are talking about the injector resistor mounted to the right side inner fender .
I have no clue what a solenoid resistor is or what point it would serve.
It gets warm but it should not be to the point of burning the paint off.
Old 08-28-2013, 04:49 AM
Guyechka's Avatar
Yes, the injector resistor. I had to look up its name, and "solenoid resistor" is what it was called. It's the solenoid with the cooling fins. I was rerouting some wiring and noticed Toyota was very careful to keep the bundle coming from the ecu well away. Plus, the last three inches of wiring going into the resistor are sheathed in heat resistant material like pyrometer wire. It occurred to me that anything with fins is going to get hot, but I couldn't find anything about just how hot or how distant any wiring ought to be.
Old 09-24-2013, 08:22 AM
86bullet's Avatar
does anybody out there know how to test a injector resistor
Old 09-25-2013, 09:17 AM
86bullet's Avatar
hot enough that you can smell wires burning after 10 - 15 minutes
Old 09-25-2013, 09:21 AM
86bullet's Avatar
why is my main fuse and relay getting to hot to touch. please help!!!
Old 09-25-2013, 10:33 AM
RAD4Runner's Avatar
Measure Current Through it and components it supplies
it is a resistor so look at FSM to see what its value should be, then measure with this
  • Measure current draw through it with this
  • Measure current draw to components it supplies, then
  • Compare with other owners'
Davebarbier
11-03-2015 03:28 PM
pickle6415
10-19-2015 08:08 AM
mreagen
10-05-2015 04:27 PM
Obmi
10-04-2015 11:30 AM
Matthew Perez
09-28-2015 05:43 PM
Quick Reply: Solenoid resistor heat?
