rod knock. please help
Old 10-21-2009, 07:02 PM
85yota4x4's Avatar
i have a bad rod knock in my truck, my friends dad says i need to re-build the first cylinder, what parts do i need to buy, and does anyone know how expensive this will be?
Old 10-21-2009, 07:18 PM
jsn_stockard's Avatar
I would do a full rebuild. If one is that bad, how good are the other three
Old 10-21-2009, 07:37 PM
85yota4x4's Avatar
so what i need to do is an engine re-build? how much would parts cost?
Old 10-21-2009, 07:46 PM
It all depends, I have done rebuilds on 22re's for around $600, but I have been building engines for years, and have a friend that owns a machine shop.
Old 10-21-2009, 07:50 PM
85yota4x4's Avatar
im talkin about just parts
Old 10-31-2009, 08:21 PM
toyotabull's Avatar
I bought a complete kit off of ebay 3 weeks ago with shipping it was $295, but I just done a quick rebuild, Bottom line you get out what you put into it, so take your time and have the crank checked, and the rods if its knocking that bad
Old 10-31-2009, 08:51 PM
camo31_10.50's Avatar
go to engnbldr...you'll definitely need a FULL gasket set (might as well do the whole thing ya know)..and a new set of bearings..then you have the option of a cam..you could bore the block and put in bigger cylinders..you could go all out and get a performance head too..lol
but if you're just wantin to get it done..i would say parts alone will be around $200-$275
full rebuild..with cam..new clutch and labor(CHEAP labor at that..he worked for pretty cheap..but he was really slow lmao) was around $1300..thats with a new crank.and new rods..lol
Old 10-31-2009, 09:59 PM
modlite's Avatar
I had a rod knock too, i pulled my oil pan off and put need rod bearings in. Fixed it
Old 10-31-2009, 10:04 PM
predator_machine's Avatar
Only on a toyota 22R or a farm tractor would I do this. And if this happened to me this is exactly what I would do.
Old 11-01-2009, 01:38 AM
toyotabull's Avatar
Toyota 22R 22RE 270/430 Cam & MASTER KIT EPN kit!!
$298.89 plus $22.00 shipping
this is the kit I got from engnbldr and everything worked/fit
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
primordialbeast117
12-19-2015 12:23 PM
83yotastockR
11
11-10-2015 06:54 AM
tylermx71
09-29-2015 08:49 PM
Quick Reply: rod knock. please help
