only for those who like mind games: 3.0 plugs in 22Re
I'm stumped, I don't see why those plugs don't work. You could try having someone crank the engine while you have the plugs out of the head but plugged into the plug wires and see if they get spark and compare with the plugs that work to see if there's any difference in spark. Also, I imagine they're the same but, are the contacts on the plugs where the wire connects the same size? If the 22RE plug contacts are smaller the wire won't make a good connection.
So instead of focusing on the spark plugs, maybe you should try looking for why it is failing emissions right now and then move on to the plugs. Check your timing and make sure that is on, make sure your TPS is adjusted properly along with your idle.
If you find what is making you fail emissions, it may be a connection to the motor running good with one type of plug but not another.
#25
steve miller
10-10-2015 01:40 AM
