New 22re is running sluggish and don't know why.
Old 08-11-2012, 12:13 PM
85toy4runner's Avatar
you might have a leak in the lower intake manifold or the upper air tank plenum . i had a leak in the upper air tank plenum when i took my fuel injectors for servicing , when i put the plenum back on i missed some old gasket material and that allowed a leak
Old 08-11-2012, 02:30 PM
BCByota88's Avatar
i already checked both of those and all vacuum hoses with starter fluid while running and found no leaks
Old 08-11-2012, 03:55 PM
myyota's Avatar
Originally Posted by 85TurboRunner
Not quite true, although our trucks did not have the vacuum advance dizzys. '84 celicas did get an early 22re with a vacuum advance dizzy.
That is true. But in 1984 when toyota first put EFI on a 22RE it was an analog EFI set up, which is a different set up than what is used now. In 1985 toyota updated to a digital EFI system, and thats whats on the 22RE now.
Do a google search to learn more about the analog EFI.
Old 08-11-2012, 06:50 PM
thanks myyota, I didnt know about the analog EFI , im looking it up now , interesting
Old 08-15-2012, 03:35 AM
  #25
Jasper 83's Avatar
I would recheck your tps adjustment. Does the idle drop when you jump the test connection? When i got my pickup, I checked the ignition timing to find it was set at like 25* btdc. Set it to 5 where ts supposed to be and couldnt hardly go 40 mph. I had no idle drop when jumping the test connector. So i adjusted the tps a lil after doin research and got an idle drop. Then i set the timing to 5* and its now the best running 22RE ive ever seen. Worth a shot.
toyota32
07-06-2015 05:42 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Jake 85 sr5
07-01-2015 06:49 PM
Land yacht
06-28-2002 09:53 AM
Quick Reply: New 22re is running sluggish and don't know why.
