Is my coil bad?
Old 03-04-2013, 07:48 PM
mainecrawler's Avatar
Is my coil bad?
My 85 runner just started acting up. At the top end of each gear at about 2800-3000 rpm, the engine is cutting out, stuttering, like I remember experiencing with my old Volkswagen that had a bad coil. Is that what this is here or could it be something else? Thanks for the help!
Old 03-05-2013, 09:35 AM
ojm3's Avatar
or the fuel pump could be crapping out and not delivering under stress
Old 03-05-2013, 11:34 AM
warpigg's Avatar
or you could have oil on your plugs my runner ran like poopy then i cleand the plugs and its better now
Old 03-09-2013, 11:53 AM
Guys at work ask if this has a crankcase sensor, they indicate that could be a problem location if it exist. Yesterday driving home in blinding snow it was a very big problem, cutting out consistently. This morning, still snowing, driving to the wife's business to shovel out, it was still snowing good, same problem. 2 hours later, stopped snowing, sunny almost, ran very well on the drive home, later driving to work, dry out, ran perfect.?
Old 03-09-2013, 04:39 PM
rokblok's Avatar
No crank position sensor on a 22RE.
Old 03-10-2013, 03:48 PM
It has to be a coil or distributor cap. It has been sunny and dry for two days and its running great. My weekend starts tomorrow and I'll try spraying some water on it to test. I'll also take a look at night for any arcing. Anything else?
Old 03-12-2013, 10:46 AM
Rusted Rooster's Avatar
Set of new plug wires cleared mine up. 1988 22re
Old 03-12-2013, 01:00 PM
Dukenukem86's Avatar
Ok similar problem here may someone can tell me something after wheelin in my 1990 toyota I was driving and it was acting like it was out of fuel hit the gas no response ans then it would get gas and almost throw me in to the steering wheel. I shut the truck of turn it back on and it stops alittle ways down the road starts again. Shut the t.
ruck off again and it stops. Any ideas?
Old 03-13-2013, 04:55 AM
ojm3's Avatar
[QUOTE=Dukenukem86;52053016]Ok similar problem here may someone can tell me something after wheelin in my 1990 toyota I was driving and it was acting like it was out of fuel hit the gas no response ans then it would get gas and almost throw me in to the steering wheel. I shut the truck of turn it back on and it stops alittle ways down the road starts again. Shut the t.
ruck off again and it stops. Any ideas?[/QUOTE
water in gas....gets in omw startup.
Old 03-16-2013, 02:34 PM
Okay, after several days of nice weather and care free wheeling, it snowed on my way home from work and it ran like hell. I mean like constant stuttering. It's only two miles home and I wondered if I would make it. So when I got home, midnight, I grabbed a light, popped open the hood and looked around. Dry inside, wires, distributor, coil, all dry. Began looking around and found the horn, yes the horn, an after market German thing, was loose on its bracket swinging back and forth rubbing the wires bare against the body. Tightened it up and took off driving again, the snow had stopped, it ran great. Go figure. I still consider it a mystery.
Old 03-23-2013, 08:44 PM
UPDATE: The mechanic at work, after I told him about my troubles, hands me a bottle of Wynn's Hi Volt ignition leak detection fluid. Just spray it on the ignition system piece by piece he says. It will show up quick. Sure enough the #3 wire began arcing on the power steering pump. Fished out some old wires and replaced #3 for now, running great.
Old 03-23-2013, 08:48 PM
Glad to hear its all straight. I'm still straightening things out on my I have to turn down work cause of it.
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
Numberonedad6
07-30-2015 07:10 PM
konah
07-30-2015 02:08 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Is my coil bad?
