Keep blowing my 80a fuse
Old 02-19-2014, 05:12 PM
Arnieg727's Avatar
Reasons this could be happening?
Old 02-19-2014, 05:28 PM
The Tick's Avatar
We're going to need more info than this. Does it blow as soon as you turn your key to auxiliary? run? Does the truck run for a while before it blows? What does the fuze go to?
Old 02-19-2014, 06:18 PM
RAD4Runner's Avatar
Amen! A problem well-stated is a problem half-solved.
What truck?
Old 02-20-2014, 03:08 PM
Arnieg727's Avatar
1985 Toyota pickup I'm not sure what it goes to but it will run for a while then out of no we're it will blow
Old 02-20-2014, 04:23 PM
RAD4Runner's Avatar
How long does the truck run before it blows? Consistent? What if truck just idles?
If same schematic as 86 4Runner. 80-Amp fuse supplies:
  • Engine fuse (15A),
  • Defogger (15A for truck), and
  • Wiper (15A).
If there is a short in any of those the lower-rated fuses should blow first. UNLESS one of those fuses has been bypassed.
A few things to check which would not cost you a penny:
  • Make sure fuses above are not bypassed and have correct rating (double check your schematic, because I'm looking at my 1986 schematic)
  • Inspect wiring to back-up switch which could be rubbing/shorting against tranny. See it here.
  • Remove fuses to wiper and defogger and drive like usual. Or leave idling and see if 80-A blows again.
Let us know what you find out.
If above does not solve problem, I would suspect something in charging system. Could something in alternator be shorting to ground - like a bad rectifier or bad winding? A bad rectifier should smoke though.
Could battery be bad that it takes too much charging current?
Old 03-17-2014, 03:49 PM
Arnieg727's Avatar
The wire that went into my fuse box had a exposed spot and I wrapped it In heat wrap and I no longer have the problem thanks for the input
Old 03-17-2014, 07:51 PM
RAD4Runner's Avatar
There you go. Cool that you fixed it. Clean robust wiring is a must if you don't want your truck to give you trouble.
Old 03-17-2014, 08:36 PM
Fossilized
Staff
dropzone's Avatar
Glad you found your short. .
puddlepirate
07-30-2016 06:29 PM
4banginRunner
11-13-2015 05:23 AM
bryan34w
12
09-30-2015 02:50 PM
Scotttekoch
09-28-2015 10:30 PM
JPV
09-28-2015 03:15 PM
Quick Reply: Keep blowing my 80a fuse
