Installing a new carrier with the same gears
Old 02-18-2009, 08:42 AM
4runner Freak's Avatar
A buddy of mine upgraded his LS to a full locker and gave me the LS.
It already has good bearings on it, and I have a spare diff that is set up.
Can I pull the carrier, remove the ring gear, put it on the LS carrier and put it back in? Will it still be setup good if I use all the same shims and clock the adjusting nut the same number of turns?
Will I still need to check runout and backlash? I will at least check the pattern, but didn't know if everything will be needed since I'm staying with the same gears.
Sorry for the newb qustion, but I've never set up a diff before and all the instructions I've found are for regearing.
TIA
Old 02-18-2009, 08:55 AM
Fossilized
Staff
dropzone's Avatar
check out Zuk's website: Gearinstalls.com
Old 02-18-2009, 09:08 AM
I have looked on his site before and it was very helpful, but again I only read the new gear installs and didn't see the same gear installs.
I just found one of his installs that explains exactly what I'm asking.
Thanks
http://gearinstalls.com/v6lockrite.htm
XtraCab
04-12-2020 05:25 AM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
deepmarsh
08-06-2015 03:44 AM
msane99
07-27-2015 06:14 PM
Quick Reply: Installing a new carrier with the same gears
