ignition coil
ignition coil
hey guys im trying to replace my ignition coil with an aftermarket product. Problem is out of the white and black wires i do not know which is pos, and which is negatgive. Any help would be much obliged!! im stuck at the house till its fixed.
Looking through wiring diagrams, you should have two wires coming off ignitor one black(ground) and one black with red stripe(positive). The only white wire I see runs from the pickup coil in distributor to ignitor.
Thank you sir but i figured it out lol. I went a bout a 6 dollar test light and hooked it up. Turns out that red line in the white wire over the last 27 years has turned it pink! haha. Just gave her new high end wires, plugs, and a performance accell coil, UNREAL it just gave me no joke 30 more hp, and cured my high idle. Last owner didnt take care of her she was chock full of junk with bad fluids and plugs nearly 5 years old.
id say its the least amount i gained. Put it like this, before the ignition top speed was bout 70 with 33's. Now i can rip past 80 easy. And i have about a 150 foot incline that stretches over 500 feet on the way to me house. In fourth gear before new ignition i lost speed and almost had to downshift. Now im GAINING speed on the same hill!
Ok so I went out a bit ago after chatting here and check the status of my factory coil. and as it turns out it's worn out, the primary resistance was on the low side of factory spec 0.8 ohms and the secondary resistance was 9.2 k ohms below Factory spec of 10.7-14.5 k ohms so this will help my little yoda! Good luck with your truck buddy
Dale Rosales glad you caught the problem that coil should do wonders...get some promo wires n a good distributor cap n rotor with brass contacts while your at it. I promise it'll do wonders! Toasty Josh ill let u know when I take a look after work.
Dale Rosales. My coil runs cool. I also replaced the cap and rotor, and wires with newer ones that have all brass contacts. It is absolutely essential that you keep all of your wires from contacting each other and metal with a coil that powerful and new parts you definitely will arc off which can cause your coil to run hot
