Holley or Weber
Old 06-18-2012, 07:19 AM
rednecktruck22's Avatar
Holley or Weber
I got an 1985 22r and it is a mud boggin truck. I plan on putting a new carburetor on it but not so sure what one to get. So what do ya'll think.
Old 06-18-2012, 12:21 PM
JonnyBoy's Avatar
My Weber tends to do pretty well when I'm in the high desert version of mud, but you may find it easier to find a snorkel adapter to save your air filter from being constantly muddied up for a Holley.
Old 06-18-2012, 02:45 PM
creswellhick's Avatar
those tons of kits for webers you might need to build the motor to push the bigger holley
Old 06-20-2012, 06:15 AM
Yeah I am lookin at a 350 Holley and in Weber I'm not too sure because I was just lookin at other forms and notice a lot of people with yotas were using Weber carbs
Old 06-20-2012, 06:44 AM
Bingle's Avatar
If you use it on the road a lot (and care about milage) I'd do an Offy dual plane and a Webber 32/36. If you mostly just thrash it in the mud and have a lot of time at WOT, Offy single plane (or similar intake that a webber bolts directly to) and a Webber 38. You can do the addaptor plate to the stock intake but they tend to leak. Just my 2c.
Old 06-20-2012, 06:50 AM
Its just straight mud boggin. No street driven. And I tryin to figure how to change my pictures but can't figure it out because its not like that anymore.
Old 06-20-2012, 06:54 AM
Bingle's Avatar
Any mods to the engine? Future plans for the engine?
Old 06-20-2012, 06:57 AM
No its all stock I thought about doin the 20r head swap but right at the moment I just doin the Carb.
Old 06-20-2012, 07:15 AM
89yota22repower's Avatar
just save the time and do the 22re swap. Not bad to do. and so worth it case fuel enjection is awsome
Old 06-20-2012, 07:41 AM
Dont want too I also got another truck I working on that's a v6 year 88 and I hate the fuel injection on it lol
Old 06-20-2012, 08:09 AM
Where do you or can you find an Iffy single / double plane at? A Weber 38 be best than a Holley 350
Old 06-20-2012, 09:36 AM
summit has them and id do a holley since my motor is built but jus get the 38 and offenhauser intake will be sweet i think you also need to buy a 20r water neck
Old 06-20-2012, 09:46 AM
Why is that get a 20r water neck?
Old 06-20-2012, 10:06 AM
well see thats where you went wrong. them 3.0's aint got nothin on the 22re boh.. But i guess we all got our opinions, i remember my first yota.. 85 Solid axle 22re 5 speed. 4 link in rear custom flatbed.. and 6.5 Cherokee coils in the front.. man didnt that thing flex.. sold it for 500 bucks :/
Old 06-20-2012, 11:36 AM
Bingle's Avatar
Check this out:
http://www.lceperformance.com/Weber-...-p/1030042.htm
They might not allways be the cheapest, but their stuff is good, complete and RIGHT, in my experience at least.
In response to the 20R watter neck:
from the link
Warning: Both single and dual plane manifolds require an 81-83 style thermostat housing
So, not the 20R, I have an 81 and didn't remember having to get a different h2o neck/t-stat housing.
One other helpful piece of info:
Warning: Single plane manifold uses an 8 bolt water plate(under manifold)
Warning: Dual plane manifold uses an 11 bolt water plate(under manifold)
There are different intakes for the 20R vs 22R engines so if you were gonna do a 20R head you either wanna do it all at once or get the 38 carb and a ONE PIECE adapter like this
http://www.lceperformance.com/Spiral...-p/1033028.htm
not the 2 piece that always leak like crazy, then get the intake when you get your 20R head.
Hope this helps!
Old 06-20-2012, 02:53 PM
I want to just do the Carb right now on my 22r. I just hear everyone doin a 20r head swap so I just thought of it. But gettin a new Carb would be a Weber 38.
Old 06-20-2012, 02:54 PM
So your sayin the v6 that I got in my other yota isn't as good as the 22r
Old 06-20-2012, 02:59 PM
Check this out:
from the link
Hope this helps!
Ok so what would all I need I got a stock 1985 22r motor what all would I need to do to have the 38 Weber Carb
Old 06-21-2012, 06:23 AM
Bingle's Avatar
Just the carb and adapter would be all you need. I would highly reccomend getting a fuel pressure regulator and gauge as well. You could just get one of the kits that come with the Redline 2 piece adaptor and run that for a while, but, they are known to be problamatic. Depends on how long before you're thinking of going to the 20R head/intake ect. I did a lot of bit by bit mods to my engine as money allowed and ended up wasting some money on parts I later didn't need when I got what I REALLY wanted.
If you're "on the fence" about the 20R head, I'd get the 38, a one piece adapter, and start saving up for a good set of headders (stay away from headdman). Headders and carb really help "wake up" a 22R. I'm sure you will see some gains from the carb but you'll see a lot more with a headder and the carb.
On a side note, I hope you don't have to do emissions where you're at. I don't know if you'd get the 38 to smog. If you don't, pull most of the emissions garbage when you do the carb, cleans up the engine bay a lot and most of the stuff hurts the running of the engine IMHO.
Old 06-21-2012, 02:51 PM
Will i have to get a new intank or does the 1 pice adaptor bolt on to the old stock 22r intank? Yeah i want to do the carb now and see how it does and if it does good then i leave it like that but i just seen that people done a 20r swap but i dont have it yet so its goin to wait and maybe never get done.
this is my truck I got a 1985 4 cly all stock its got a 3" suspension and a 2.5" body lift on it with 33"TSL Swampers the front and rear gears are welded with 4.10 gears its got a 3" exhaust split in to stacks coming out of the bed
Quick Reply: Holley or Weber
