HELP- window rolls down when headlights are on
What's up all, first time posting on the forum & excited to be here!
Hoping someone has run into this and can give me some much needed help.
1985 4runner, pretty much gutted interior as I am working on the build.
It has a fun little trick that has happened since I've had the truck.
Rear window works decently well, all things considered. (newer tailgate from an SR5, was on it when I picked it up)
However, when the rear window is up, and I turn on the marker lights or the headlights, it immediately rolls down.
I then disconnected the window switch with the window up, and turned the headlights on, and the window did not roll down.
Wishfully thinking, I hoped it was the switch. I replaced the switch with a new aftermarket one, and no dice. Window still rolls down whenever the headlights are on.
Hoping someone has run into this and can point me in the right direction, any help is GREATLY appreciated!
That 1985 is hopeless. Sell it to me. :
Welcome to the forum!
Does it happen even with ignition off? Need to narrow down becauase there are 2 power sources for window control.
Does it happen only from window up? Never rolls up from window down?
Does window work normally when lights are out?
Possible short between lights wiring and window wiring? (left side body cavity). With lighs out in the dark, have someone cycle window up/down while you look closely at lights if they blink, or better yet, monitor voltage on tailllight positive wire.
How window control works with schematic here:
https://www.yotatech.com/forums/f116/how-rear-roll-up-window-works-304516/#post52399326
The following users liked this post:
old87yota (01-11-2022)
derockus
11-03-2013 06:13 PM
colsoncj
11
09-15-2004 10:13 AM
