Help with my clutch replacement!
Old 03-31-2012, 12:15 AM
RAD4Runner's Avatar
Speaking of Clutch Master Cylinder,
If you have replaced or rebuilt them, please share your Real-life, First-hand experience.
Replaced or rebuilt?
Which brand did you use?
What brand-model would you recommend or stay away from?
Price?
Any first-hand experience with:
Power Torque Part # CM1196 from OReilly?
WAGNER Part # CM108214 from www.Rockauto.Com ?
Aisin (of course, but it's a little pricey)?
TIA
Old 03-31-2012, 11:18 PM
kiwicowboy's Avatar
I've replaced my clutch master cylinder with a Wagner and never had a problem. That was a few years ago when Wadner parts were still made in USA. If it's made in China now, keep looking. I have not found any Chineese part that lasts more then a month or two and thats if it was good to begin with.
Old 04-01-2012, 12:48 AM
wyoming9's Avatar
Red face
I used to keep a rebuild kit for both the master and slave cylinders but found that most of the time the cylinder bores are so pitted they are not worth rebuilding . they will work but no telling how long
i have used many different brands from Napa to what the independent auto parts was selling.
They all work they all wear out i think the fact we all sort of just forget about them till they fail .
The fluid needs to be changed just like the brakes.
Old 04-03-2012, 10:54 PM
RAD4Runner's Avatar
Thanks a lot, guys!
Yes, pitted wall is my concern; don't wanna spend time taking thing the thing apart only to have to wait for whole replacement, anyway. I found a brand-new (Taiwan!) one from OReilly's for $20 with lifetime warranty so I'll give this a try. Really wanted the Aisin but too pricey.
Yes, current fluid is way too dark. To help make sure most of the old fluid is purged, I'll disconnect from the slave cylinder and purge with new fluid before reconnecting to slave. Then, I'll bleed the whole system.
Originally Posted by wyoming9
...most of the time the cylinder bores are so pitted they are not worth rebuilding... . they will work but no telling how long...
Originally Posted by kiwicowboy
I've replaced my clutch master cylinder with a Wagner and never had a problem... If it's made in China now, keep looking....
smthwsn357
05-01-2024 07:28 AM
the1998sr5
15
07-14-2020 08:35 PM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: Help with my clutch replacement!
