Help!! '85 22RE code 13-Knock Control CPU
Old 10-22-2012, 09:09 PM
ballzer5169's Avatar
Just finished up a rear main seal replacement (pulled tranny/transfer case). Before starting up, i pulled coil wire and check compression on all 4 cylinders. coil wire arked out while checking #3 (4-5 cranks). Compression checked out OK and finally fired up. Check engine light is now on constantly. checked codes and pulled a 13 - Knock Control CPU. Engine seems to run fine but I can't figure out what's wrong or if the coil wire arking out has anything to do with the code 13. Any Help would be awesome.
Old 10-23-2012, 03:44 AM
Crtzlow's Avatar
Has the wire came off the knock sensor? Located above starter, about halfway up the motor and about middleways. Possibly a yellow connector. Not to be confused with the oil pressure sending unit.
Old 10-23-2012, 06:36 AM
I checked the knock sensor and the wire appeared to be fine. I need to check wire and sensor further. The wire has been replaced once by someone other than me over 12 years ago.
montanatruck
02-26-2017 07:07 AM
nonstop
07-24-2015 06:29 PM
jake_v
07-22-2015 03:17 PM
1994toyota
07-17-2015 03:03 AM
mengquis
07-13-2015 10:39 AM
Quick Reply: Help!! '85 22RE code 13-Knock Control CPU
