HEI for the 22r and 22rec
Old 05-05-2009, 06:12 AM
revhardjustice's Avatar
ok guys, does anyone know of an HEI system that can go into the 22r and/or the 22rec? i have 2 22r's and 1 22rec, between the 2 trucks i have. both trucks are 85's. one of the engines in out of a 93 and was a 22rec and got converted to a 22r. i like the carbs better than the inj. want to go to the Weber 34/34 on everything.
but back to the point, is there an HEI system for the 22r and 22rec engines?
thanks for your help and info.
Old 05-05-2009, 10:03 AM
Outsane's Avatar
here is one on a Land cruiser
http://carmutations.com/tiki-index.p...Cruiser+2F+HEI
Old 05-05-2009, 10:08 AM
Outsane's Avatar
and here is a thread with guys using 22r dist. on Motorcycles to get HEI..
http://xs650temp.proboards.com/index...nt&thread=7899
Old 05-05-2009, 10:22 AM
BigBluePile's Avatar
http://www.performancedistributors.com/toyota4dui.htm
Old 05-05-2009, 10:26 AM
Outsane's Avatar
and I'll take all your EFI stuff off your hands...
Trade you for all my fancy carbed stuff! including offy intake!
Old 05-05-2009, 04:46 PM
brownbagg's Avatar
just use the one off a 22r. all it takes is a hot wire
Old 05-10-2009, 11:26 AM
thanks for all the help guys. i'm going to try the 22r way first and then see where this leads me. i have a spare one laying around. i'll post and let you know how it goes.
Old 05-10-2009, 11:28 AM
EFI for Carb
is it a standard carb or the 34/34 weber set-up that i want to change to?
Old 05-10-2009, 03:50 PM
Old 05-10-2009, 06:49 PM
abecedarian's Avatar
If I were carb'd, I'd probably look at a CDI system first. If that didn't work, I'd stick with stock.
After all, what do you mean by HEI?
Old 05-10-2009, 08:18 PM
High-Energy Ignition system (HEI). These HEI systems fire a considerably "hotter" (increased voltage) and "fatter" (higher amperage) spark across the spark plug electrodes.
Old 05-10-2009, 08:31 PM
ozziesironmanoffroad's Avatar
on 22rs i doubt youll see much differnece. thats for big block vhevies and fords. performnce engines. and a performnce engine 22r/22re is not.
Old 05-11-2009, 05:46 PM
XtraSlow_XtraCab's Avatar
Uh... HEI pretty much came standard on a lot of cars by the mid-80's and was by no means limited by engine size and performance. Granted I have not looked to see if these are points or not, but they're probably fine. There won't be a power difference, but perhaps a smoother-running engine and a PINCH of fuel mileage.
There were threads floating around on using the HEI from a mid 80's Chevy straight 6. THose engines were crap, they made the intake and head a one piece mold in those days.
buckz6319
08-05-2017 03:50 AM
Iceman4193
10-16-2015 10:50 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
puddlepirate
09-29-2015 08:02 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: HEI for the 22r and 22rec
