head gasket job,trying to remove exhaust manifold
I cant seem to get the exhaust manifolds off the heads so I can remove heads to replace head gaskets.I tried at the crossover behind the heads also.Heated the two I could reach and got them free,now Im dremeling the one I cant get the torch to or even a wrench on.This is my last step so I can get heads off and start rebuild.Been at it for 3 days solo and Imgetting frustrated.Help.954x4 pickup 3.0 V-6
Ended up Dremel cutting 4 of the nine
I wish I had just cut all nine of them.After dremel tool cutting the four Icouldnt free up I drilled them out and replaced them with nuts bolts and lock washers,it was ten times easier than putting the stock nuts on the other five.If I ever do this again(hope not) I will cut them all.
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
