front wheel studs
Old 06-21-2011, 11:12 AM
85 FF / medic's Avatar
front wheel studs
Ok , I searched and found a thread with the NAPA part # for front wheel studs and they are still to short. I have the V6 front rotors and calipers and run a 1.5 inch spacer. When I put the NAPA studs in, I get like a 2-3 turn bite on them. Are there extended studs out there? are 2nd gen studs longer?
Old 06-21-2011, 11:13 AM
waskillywabbit's Avatar
I use OEM with no issues.
:wabbit2:
Old 06-21-2011, 05:09 PM
Were you able to pund them up to flush with the back of the rotor? I have destroyed 3 of these things doing the washer stack / impact gun trick.
Thanks,
Brian
Old 06-21-2011, 08:00 PM
4Crawler's Avatar
What length do you need? I've used the Dorman 1/2x20 studs for many years now.
610-144 = 2-7/8" long; ~3/4" longer than stock fronts
610-073 = 2-3/8" long; ~3/4" longer than stock rears
Sure, different thread lug nuts, but the same socket fits both the 1/2" and 12mm nuts.
Old 06-22-2011, 04:35 AM
That is what I need.... thanks!
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
tj884Rdlx
08-28-2015 12:04 PM
1994toyota
07-17-2015 03:03 AM
skoti89
07-06-2015 07:45 PM
Quick Reply: front wheel studs
