Engine swap options with o body lift
So I love my 22RE but I just added a Exo-Cage and am looking for more power to get to the trails. I already have 4.88's and dual cases (21 spline) and am looking to go with the combo of Easiest, Best Torque Curve, Most Cost effective.
I've been looking at the 3RZ and the old supra engines. I don't need more pwer for crawling with the dual cases, and don't want a ton of power either so my drivetrain stays pretty bulletproof. Just looking to get more power below 3500 rpm and be a little more fun to drive on the street, as well as kicking some ass in the mud
Thanks
Pic of exo in progress
Thanks
nice 4runner . I also have a white 85 its stock though . just wondering , how much your exo-cage weighs ? I wonder if you put a nice performance head with a decent cam, headers and exhaust if that would give you the little extra power you would want
I'm guessing about 350 lbs. it's 5 sticks of DOM and sliders and bumpers are probably near 200-250? pounds. Plus the winch is about 80 pounds or so... Factoring all the other armor, extra case, tires and beadlocks and misc. stuff not counting HI-Lift and recovery tools (or me, my dog and and camping gear) I've probably added 900-1000 lbs... Holy Cow! I swear I wasn't trying to build a tank
I'm running 4.88's right now and Trail Gears Coald air intake and headers and thinking for what it takes to get 150 hp. I could swap a new engine for not much more I was thinking if the 1JZ non turbo would fit with a W58 I just have to swap my Transfercase input? And slap her in and rewire her? It seems like it will fit with the motor mounts and radiator, any issues ill run into along the way? Is it a much tougher install than I think?
I should have said in the beginning as well please Toyota made engines only way to loyal to ever leave a Yota engine
My buddy is swapping in a 3rz right now, i think if your looking for a little extra umph this would be good for you. Nothing outragous so your not going to break stuff and you can still have fun with it. And the damn things will run almost upside down. Just make sure all your main parts are from the same truck. Piecing harnesses together isn't fun and really drags out the process.
I'd say a 2.7 or a 3.4.
Having gone from a 22re to a 3.4 in my truck I would probably lean toward the 3rz. For a trail oriented rig with little or no towing the lighter weight of the four banger would be a little more nimble imo.
If you need more power you can always go with a turbo or a supercharger.
6th Gear
19
12-10-2019 07:31 AM
dandownunder
06-10-2002 06:18 AM
