back window wont go up....
Old 10-02-2011, 08:49 AM
bdales's Avatar
hey im workin on my 87 4runner and i just replaced the back window and the back window motor....F*&#er still wont roll up . its almost winter and its raining hardcore....im sure its some stupid F*&#$in sensor that is fried and it thinks the tailgate is down.....how do i disconnect/bypass all the sensors and how many of them are there? this is so frusterating....wiring is my weekness it frusterates the hell out of me.
Old 10-02-2011, 08:50 AM
bdales's Avatar
and yes i made sure the tailgate was locked and closed all the way...
Old 10-02-2011, 10:31 AM
gary_the_4runner's Avatar
check your cover top switch, it might think your top is off and therefore wont let you roll up the window.
Old 10-02-2011, 11:00 AM
evileyejones's Avatar
for emergency temporary measures: you can use hardwire the motor to get it up (while it is closed and locked).
It won't solve your problems, but it will let you keep it all protected from the weather while you track down a short or grounding out wire or something.
Old 10-02-2011, 11:48 AM
guide4078's Avatar
mine wouldnt roll up cause the rear window lock button was broken, in the lock position,so i removed lock button and just jumpered it at the connector and SUCCESS, it rolled up!!
Old 10-03-2011, 04:14 AM
seabee 86's Avatar
Did you test the switch on the center console?
Do you have good ground?
Is it possible the key tumbler in the tail gate is crunchy after years of use and it's not going all the way left or right?
Old 10-03-2011, 06:30 AM
Staff
Terrys87's Avatar
Your rear wiper needs to be in the stowed position also. In a pinch run two wires right from the motor to a good ground and hot wire operate the window.
In my build thread below, I tried to put alot of information about the rear window on post #185 and #186.
Old 10-03-2011, 07:19 AM
runs-on-4's Avatar
if your switch doesnt click its probably bad, my brother and i put toggle switches in his. im not quite sure what wires went to what though.
Old 10-03-2011, 12:07 PM
seabee 86's Avatar
A very good point I over looked while fighting the window in some very cold windy rain...I eventually said eff it.
Old 10-03-2011, 12:19 PM
bdales's Avatar
Hey thanks a bunch guys. This has been such a huge headache. Turns out it was my canopy sensor or bolt "a" on factory diagram. The bolt is supposed to be shorter than the rest so it doesn't damage the sensor when you tighten it down. I unknowingly used a regular bolt and crushed the sensor. So I did what Terry suggested and hardwires the motor to a aux switch that I installed inthe dash. Thanks again guys!!!
Old 10-03-2011, 05:15 PM
hrt4me's Avatar
Originally Posted by bdales
Hey thanks a bunch guys. This has been such a huge headache. Turns out it was my canopy sensor or bolt "a" on factory diagram. The bolt is supposed to be shorter than the rest so it doesn't damage the sensor when you tighten it down. I unknowingly used a regular bolt and crushed the sensor. So I did what Terry suggested and hard wired the motor to an auxiliary switch that I installed in the dash. Thanks again guys!!!
do you happen to have a photo which depicts the bolt "a" you are referencing (because a picture is worth a thousand words...)?
Old 10-03-2011, 05:17 PM
you can also....
jumper that sensor (or even the sensor plug, if it's broken), to bypass it and keep the rest of the system intact.
but if you already rigged another switch and everything then no big deal.
Old 10-03-2011, 06:58 PM
bdales's Avatar
Well I don't have mine anymore didn't think/know about it when I put my canopy back on. But it looks the same as the other bolts, just shorter.
Old 10-03-2011, 07:05 PM
bdales's Avatar
Yah I just realized That there is way to many sensors to go through it all right now I just want it to work for now then I'll figure it out when I have some more time. Wouldn't be hard to change it back once I fix the problem
Old 10-06-2011, 03:49 AM
hrt4me's Avatar
Actually, I should have been more precise, because I meant a photo of which location in the truck denotes Bolt "A" ?
Old 10-06-2011, 04:45 AM
should be the second from the back. pull the rear side panels and you will see a little black box right under where a bolt goes., pull it and jumper it with a wire and then you never need to worry about that bolt ever again.
Old 10-06-2011, 08:16 AM
also... look up higher on this very same thread and someone posted a picture of all the sensors. its on there as well.
Old 10-06-2011, 01:02 PM
mainecrawler's Avatar
I need to replace the motor to the rear window! Will the motor from the passenger side power window replace it?
Old 10-06-2011, 01:04 PM
I think I read somewhere that any window motor will work. don't quote me on it, though...
Old 12-03-2017, 07:56 AM
The Garda music's Avatar
1989 Toyota 4Runner rear window issue
Hey guys...
so I took the top off and recently put it back on.
the driver side 2nd bolt from the back has the sensor everyone knows about. What I didn’t know is when you put the top back on you have to remove the cover next to the roll bar and underneath the sensor you have to push up on the piece of plastic to get it back to top on mode.
took about 5 min to do.
and about 2 months of headaches to figure it out
Quick Reply: back window wont go up....
