Any threads on replacing throw out bearing?
Old 03-04-2009, 05:13 PM
1990arizona4runner's Avatar
I am looking to replace the throw out bearing on my 1985 4Runner, 22re w/ 5 speed manual transmission. Are there any threads on how to do so? I have searched but had no luck.
Old 03-04-2009, 05:19 PM
JasonWin's Avatar
Any thread about replacing a clutch should give you all the information you need.
Old 03-04-2009, 05:22 PM
I seen some clutch replace threads but none really focusing on the throwout bearing
Old 03-04-2009, 05:29 PM
Windsor's Avatar
I've swapped out throwout bearings in other vehicles and the hardest part was always getting the transmission away from the engine.
The Toyota FSM mentions a retaining clip as the only thing to look for once you are actually eyeballing the throwout bearing.
Old 03-04-2009, 06:46 PM
BigBluePile's Avatar
So, do you JUST want to know about the throw out bearing? Pack bearing full of grease and using a bolt of the same bore, smoothed, pack the grease in behind the bearing. Repeat as required till the bearing pops out.
Old 03-04-2009, 06:55 PM
Windsor's Avatar
Are you talking about the throw-out bearing or the idler bearing?
Old 03-05-2009, 01:43 PM
83's Avatar
I think Big Blue Pile's thinking of the pilot bearing. The throwout bearing isn't too hard...once the transmission is out.
I had a heck of a time getting mine off the bearing hub...I don't have a very stocked garage and couldn't find something that fit to press it off. I finally just took it to a machine shop and had them do it. Any local small garage would probably do the same, probably for free, or along with some other service, like if they were changing out your tires or whatever you still bring your truck to a shop for.
Old 03-05-2009, 02:55 PM
Windsor's Avatar
Yeah, I have a pilot bearing tool (I called it "idler bearing" above, whups). Three fingers that expand when you thread the rod inside, a slide hammer on the human side of it.
I bought the tool for RX-7s, it can be used with most other vehicles.
Old 03-05-2009, 03:31 PM
Thanks Guys. I am going to try it this weekend so I'll let you know how it goes. I have the FSM buts its pretty vague. It doesn't look too bad though but we'll see.
Old 03-05-2009, 05:01 PM
oops, sorry! I'd probably do both just while I was in there! Seems like a lot of work though just to do that ONE bearing? Is this stuff all original equipment?
Old 03-06-2009, 06:43 AM
83's Avatar
Yeah, if you're pulling the transmission, then obviously replace the clutch, pilot bearing and throwout bearing.
Old 03-06-2009, 07:32 AM
I have already replaced all the other bearings and clutch (i bought a rebuilt longblock). I figured while I am waiting for my 4.7 Marlin gears to get installed I might as well change the throwout bearing as well.
Old 03-06-2009, 10:38 AM
83's Avatar
Yes it would be very silly not to replace it. Any time you replace one part of that system, replace it all, clutch pilot and throwout.
Old 03-06-2009, 10:26 PM
88alltrac's Avatar
dont clutch kits always come with TO bearings? if you have the tranny off it is very simple to replace. you will know how when you look at it.
actually are you thinking of the right bearing when you say throwout bearing? the throwout bearing just makes contact between the clutch fork and the pressure plate.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
skoti89
07-06-2015 07:45 PM
Quick Reply: Any threads on replacing throw out bearing?
