86 22re will not start
Old 07-09-2011, 01:22 PM
jason in tn's Avatar
quick back story, I recently rebuilt this engine on initial start up it fired right up but was running really rich and has went down hill from there. after cleaning the AFM and throttle body it would not even start. so my check list so far has been.
pulled dizzy and reinstalled tmake sure timeing was right.
pulled codes came up with 6 and 11 which are igniter and TPS.
swaped igniter and TPS with known good parts no change.
pulled codes 6 and 11 again
tested TPS checked ok.
checked for spark at plugs good.
checked for fuel at fuel return good stream while cranking.
thats where Im at I know you can check the injectors at the conection to see if the getting signal but Im sure they are not. really need some help fellas.
Old 07-13-2011, 02:58 PM
myyota's Avatar
Check the solenoid resistor, if it goes bad the injectors won`t function. I had this go bad on my 86 4Runner.
bigjstang
08-25-2021 12:41 AM
Yota.Jay
07-23-2015 08:08 PM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 86 22re will not start
