85 pup thrown rod. Sell/part out or fix it?
Old 03-25-2013, 04:45 PM
Philbert's Avatar
Wow that cylinder looks awful - glad you were able to limp home!
I say save the truck - with the Carbed engine or whatever you can do under budget. Sounds like you have a sane approach and agree with all of us about saving it
Good luck and keep us posted!
Old 05-19-2013, 09:45 PM
Mirage88's Avatar
Progress finally made!
I have the 20r engine in. The valve cover had cracks so I used the valve cover from the 22rec. I still have all the do-dads to hook up. The engine is from a California emissions truck, so the carb is bristling with vacuum ports.
I replaced the in-tank EFI fuel pump with a piece of copper water line tube. The end had to be turned smaller to fit the filter screen. i'm actually glad i went this route as when cleaning the fuel tank pickup assembly, i located four pinholes in the return line. fuel has been seeping out for some time.
In order to fit my budget, i opted to go with the Chevy coil/igniter solution.
bigjstang
08-25-2021 12:41 AM
crammit442
7
11-29-2017 12:30 PM
Peevedkitten
11
08-31-2015 06:57 PM
vanion2
07-29-2015 06:17 PM
cgilley
07-25-2015 10:55 PM
Quick Reply: 85 pup thrown rod. Sell/part out or fix it?
