85 Manual Trans Neutral Safety Switch???
Old 01-16-2009, 05:23 AM
loveR's Avatar
Question 85 Manual Trans Neutral Safety Switch???
Okay, so I just got an 1985 Toyota Extra Cab 5speed EFI SR5 4x4... first truck of this age group I've owned, drove or really even looked at for that matter so be easy on me
... my other Toyota Trucks that I have/owned were an 1994 & 1995 early.
Have a couple "issues" I'm addressing ...
This thing will start without depressing the clutch, which isn't a HUGE deal just would like to know; SHOULD this thing have a Neutral Safety Switch for a manual trans of this year? I tried searching the forums but only stuff I seemed to come up with was a few threads on Automatics having them.
If it is supposed to have one, where are these typically located? I never had to mess with one, would this be at the pedal area of the truck or on the trans itself?
If its any help to troubleshoot it also doesn't turn the reverse lights on when I put it into reverse... bulbs and fuses are cool... I have a reverse switch on order from Toyota. (hoping that's the fix)
Old 01-16-2009, 06:44 AM
eric-the-red's Avatar
I don't know if 85s had a safety switch but if it does it would be on the clutch pedal. There is no neutral safety switch on a manual, they have a switch on the clutch pedal that only allows starting when the pedal is depressed. If you look up to the top of the clutch pedal there will be a switch attached to the bracket.
And with the reverse lights you can check if it's the switch by just jumping the 2 wires that go to the switch. If the lights go on then it's a bad switch, if not there is another problem. You may want to check before you get the new switch because you probably won't be able to return it.
Old 01-16-2009, 06:51 AM
DC.Woods's Avatar
No neutral safety switch on my '85 4RNR 5sp.
Old 01-16-2009, 03:41 PM
ephwang's Avatar
None on my '85 XtraCab 5spd.
Old 01-16-2009, 05:22 PM
loveR's Avatar
I will give it a look... maybe the clutch pedal depression switch or whatever that would be called doesn't exist on 85's I will get under there and look.
as far as the reverse switch and jumping it to test it. THATS definitely the right way. HOWEVER I am all for just buying it and trying it LOL... it was only 34 bucks from Toyota.
anyone have an 85 that you need to press the clutch in to be able to start it???
Old 01-16-2009, 05:28 PM
DC.Woods's Avatar
I don't understand the benefit of a NSS. I consider NOT having one a BONUS. back-up lights can be handy though!
Old 01-16-2009, 05:52 PM
darksoldier313's Avatar
i admit i have moved my poor broke down truck of the road with the starter before tough lil thing if i must say so my self
Old 01-16-2009, 05:59 PM
4Crawler's Avatar
Yep, no NSS or clutch cancel switch in the '85 models, I think that started in '86. For the reverse light switch, it is in the transmission, driver's side near the fill plug. See if it is plugged in or if the wiring is damaged.
Old 01-16-2009, 09:41 PM
loveR's Avatar
roger that. I will get under there and take a peek.
Not to hi-jack my own thread or anything. someone who will stay un-named said that the standard cab long bed and the extra cab short beds use a drivershaft /bearing carrier combo type drive line. Is this true??? my extra cab short bed only has two u-joints and a one piece driveshaft. (it was damn near as stock as it gets so I would like to believe thats the right setup??)
Old 01-16-2009, 09:51 PM
Ed H.'s Avatar
my 84 standard cab long bed has a carrier bearing
Old 01-17-2009, 07:06 AM
loveR's Avatar
anyone else has a extra cab with this type of setup?
Old 01-17-2009, 07:25 AM
4Crawler's Avatar
You'll find both types of drive shaft setups under the 2nd gen long bed and extra cab pickups. Seems to be no rhyme or reason to which drive shaft went in which type of truck. Most got the 2-piece shaft with center support bearing, but some got the 1-piece with u-joints like the short wheel base vehicles did.
Old 01-19-2009, 02:56 PM
hmmwv15's Avatar
My 85 doesn't have the clutch safety, I just figured that out last weekend. (Obviously made sure it was out of gear)
My 87 xtra cab long bed (2wd) has the 2 piece shaft in it.
Old 12-27-2021, 12:07 PM
Darylzane's Avatar
85 base 2wd pickup
So with no NSS and not seeing any kind of switch whatsoever attached to clutch pedal does that mean that I can start this truck without pressing in the clutch. I see the brake switch and then I also see another one but... Here. So what is this on the steering column? There are a lot of pieces from my truck missing, for instance no compressor.
No NSS?
So what is this?
Old 12-27-2021, 12:13 PM
4Crawler's Avatar
Yep, no NSS or clutch cancel feature in the '85 models AFAIK. I think that started in the '86 models. I start in gear all the time on the trail when in low range. Works great for starting out on a steep uphill, just turn the key and go.
The following users liked this post:
2ToyGuy (12-28-2021)
KBar
08-03-2015 05:14 PM
KBar
07-13-2015 06:01 PM
Poncho0206
07-10-2015 06:21 PM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 85 Manual Trans Neutral Safety Switch???
