85 22re brake booster/issue causing surging idle
Old 01-26-2014, 09:18 PM
4Crawler's Avatar
May be the TPS, especially since you are getting a code. Easy enough to test and find out for sure. But it may also just be misadjusted and that can cause you to set the timing wrong and that can cause the idle to be too high. On my 22RE, if I go to about 7 BTDC I can't get the idle down much under 1000 RPM.
Might also want to check the dash pot:
- http://www.4crawler.com/4x4/CheapTri....shtml#Dashpot
If it sticks open or is slow to close, it can give you high RPMs between shifts.
Old 05-03-2014, 05:20 PM
FGZ
FGZ's Avatar
Originally Posted by 4Crawler
Likely the idle speed it too high and/or the TPS is bad or improperly adjusted:
- http://www.4crawler.com/4x4/TLCA_Tru...ech.04.09.html
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
That first link sounds spot-on to what mine is doing. Ever since my timing set job I've had the idle up/down/up/down issue while braking. Since I had a very stretched chain, I had to adjust the timing a bit when I was done with the job...plus I don't know what the timing was at in the first place, but regardless the idle was set according to that old timing with the old chain. Now I put on a new chain and redo timing and the truck idles higher and then this braking idle issue starts acting up.
I'll adjust idle down, I hope it fixes things.
Old 10-11-2014, 07:55 AM
sea dawg's Avatar
Did this one ever get solved?
Old 10-12-2014, 03:25 PM
otis80's Avatar
Yea it did actually. I did two things at the same time to try and fix the problem. So I'm not exactly sure which one actually fixed it. But the first thing I did was cleaned the IACV. Then I read that the idle adjustment screw can let air leak in around it. So I put some plumbers tape on that screw. Like I said before though, I'm not sure which one fixed it. But she runs great now!
Old 10-12-2014, 09:58 PM
  #25
sea dawg's Avatar
Sorry for my ignorance, but what is an IACV??
Old 10-13-2014, 04:02 AM
  #26
otis80's Avatar
Intake Air Control Valve. It is a mecanism that checks the coolant temp for the high idle. If the coolant is hot it shuts off the high idle, if it's cold then it gives the engine more air so the high idle works. Someone probably has a better definition though.
Old 10-13-2014, 08:08 AM
  #27
sea dawg's Avatar
Thanks. Is this one of the two sensors that sits below the thermostat on the 22RE? If so, I've replaced and checked them.........
Old 10-31-2014, 02:46 PM
  #28
Schnayke's Avatar
There are two kinds that, one is under, and attached too the throttle body. The other is right next too it on the intake. You will have one or the other, but best way to find them is too fallow the coolant hose too it. I opened mine up and found a bunch of silicone in it. But sadly it didn't fix my idle issue. I then found the idle up valve too be my issue. It is stuck open so it sucks air always. I plugged the ac vacuum line and it fixed my surging issue. I still currently have a high idle issue, though. It idles too high when cold. Anyhow hope that helps you even though it is likely a couple weeks late. lol
smthwsn357
05-01-2024 07:28 AM
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 85 22re brake booster/issue causing surging idle
