84 Bell crank
Old 08-19-2011, 07:45 PM
jhoko's Avatar
84 Bell crank
anyone got or know were i can get a cheap bell crank? hit me up and let me know thanks.
Old 08-19-2011, 07:50 PM
85gijunk4x4's Avatar
parking brake bell crank?
http://www.villagetoyotaparts.com/pr...763335010.html
Old 08-19-2011, 08:35 PM
jhoko's Avatar
yah that p.o.s.
Old 08-19-2011, 09:11 PM
ever consider eliminating it, and switching to a transfer case brake?
Old 08-19-2011, 09:22 PM
jhoko's Avatar
never heard of it how does it work?
Old 08-19-2011, 09:26 PM
bassicly, instead of using your rear drums for the parking brake, you get rid of all that stuff, and mount something similar to a disc brake behind the transfer case, and it locks your driveline. talk to YT'er teuf, i think he has one.
http://www.4x4wire.com/toyota/reviews/parking_brake/
Old 08-19-2011, 09:28 PM
jhoko's Avatar
sounds badass but on a budget thats y i was hopin someone had one for sale
Old 08-19-2011, 10:13 PM
wyoming9's Avatar
Smile
Just what is it you need??
The Bell Crank is made of steel and unless they are beat up from being beat on with a hammer I reuse them just clean them up.
The bell crank brackets are aluminum and the steel pin just seizes up if you don`t use the E-Brake or the vehicle sits for a long time.
You might find someone parting out a truck with ones the were done not to long ago. Perhaps Dave`s might have some from a nice California Truck Other than that dealer only.
Since this is a common problem I always keep these in the parts inventory.
Old 08-21-2011, 06:33 PM
jhoko's Avatar
i just need the housing im pretty sure i can salvage everything else
Old 01-05-2015, 06:27 PM
trth's Avatar
I know this is an old thread, but I'm looking for a bell crank for the parking brake and none of the autoparts stores carry them, and the local junkyard didn't have any that fit. I have an 1985 4x4...
Old 01-05-2015, 11:03 PM
wyoming9's Avatar
Red face
Just what do you need???
The bell crank is the steel arm. Unless they are beat on with a hammer I can clean them up and reuse.
The bell crank bracket is the aluminum piece the arm is attached to that mounts to the backing plate.
Most all the brackets I remove come off in pieces.
You might find one from the dry southwest on a truck being parted out.
Or new from the dealer.
Old 01-06-2015, 03:02 AM
MAINETOY's Avatar
Bell Crank Housing
I have a bell crank housing,how many you need? PM me
Old 01-06-2015, 12:08 PM
wyoming9's Avatar
Red face
Bell crank Bracket !!
mbomberz1
10-09-2015 07:17 PM
93RedKrawler
09-25-2015 04:03 AM
Armstrong486
09-19-2015 12:37 AM
themightykhoner
09-18-2015 02:28 AM
Corvoid
09-14-2015 10:10 AM
Quick Reply: 84 Bell crank
