84-85 Pickup and 4 Runner Headlight upgrade
Old 05-22-2014, 08:34 AM
LCE_Performance's Avatar
Are you tired of driving down the road with the DIM factory headlights.
you know the ones that im talking about.
The old style Halogens, that emit a yellow, darkish color light.
If you are, you are in luck with the HEADLIGHT CONVERSION.
With this set up, you will go from the sealed glass lights to a nice set up.
It will have the replacement Headlight housing that is a durable plastic.
The bulb is switched to a H4 style bulb that is replaceable.
There is 2 different style bulbs that you can go with.
You can go with the regular H4 Halogen style bulb, this is going to be a little bright than what you have now.
Or you can upgrade that to the Vision X H4 bulb, this bulb is a step down from a HID..
With this your night driving problems are solved.
Less strain on your eyes as you are driving down some old 2 lane highway in the middle of nowhere. Or if you are like the guys here at LC, Some old dirt road or up in the mountains..
Check this out and let me know what you gentleman think..
Here are the links for you guys.
The 1st is the Regular H4 bulb
The 2nd is with the Vision X H4 bulb
http://www.lceperformance.com/H4-Hea...-p/3061016.htm
http://www.lceperformance.com/H4-Vis...-p/3061020.htm
Andrew
Old 05-22-2014, 04:12 PM
jimbyjimb's Avatar
Shouldn't this also pop right in to the 82-83 rectangle headlight 1st gen?
Sure is a crime if they don't cause I like my rectangle headlights!
Old 05-27-2014, 08:48 AM
Yes this head light kit will pop right in the place of yours.
You should have no problems with the fitment on it.
We just put some on a truck here in town.
And we ran into no problems at all.
Old 05-27-2014, 08:58 AM
osv
osv's Avatar
you guys should offer a toyota-specific replacement headlight harness to go along with this... one of those units that switches power directly from the battery/charging circuit(??), instead of sending all the juice through the headlight switch on the steering column.
Old 05-27-2014, 09:09 AM
With what you are saying, are you trying to hook the lights up to its own little Toggle Switch?
With these kits it is not going to put more amperage through the factory wiring, it will not cause any more stress.
And as for the harness, as of right now we don't deal with any of the harness's, but there is a company out there that I know about that might be able to get them.
Off Road Solutions
Old 05-27-2014, 09:20 AM
osv
osv's Avatar
i believe that it's a solid state transistor switch, with wiring, pretty reasonably priced... there is a company that makes a generic type of harness, with the transistor switch in it, that people adapt, but when i looked at this a few years ago, there weren't any specific solutions for our trucks.
i'll check out ors, thx
Old 06-13-2014, 01:30 PM
Toyotero's Avatar
LCE, That's a great looking kit.
I picked up this similar Hella kit and a relay/wiring harness from 4Crawler (made in China) a few years ago and I've been satisfied with it.
Roger Brown wrote some info about the factory light circuits on his 4Crawler site. I had the same problem in my 88 4Runner light switch, I'd change to brights and the lights would go black until I changed again on occasion. I disassembled the switch mechanism and my switch contacts were pitted partly from age and partly from the power going through the contacts. Reducing power through the switch with a relay circuit is advisable, especially if upgrading headlights.
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Lights: Hella H6054 200mm Rectangular E-code Hi-Lo Conversion Headlamp Kit.
(note, the kit is E-code, not DOT approved, these are the DOT Lights)
Wiring kit: http://www.4crawler.com/4x4/CheapTri...OnLineOrdering
(general product image, mine had the correct plugs for the 4Runner factory harness.
The difference between this lkind of lights and the sealed beams is night and day.... before was like driving by candle light, after is like driving with a lighthouse lamp on the front of the vehicle.
Old 06-13-2014, 03:23 PM
osv
osv's Avatar
looks like lowrange has a similar harness to that 4crawler version, for $29, with the factory headlight plugs(?):
http://www.lowrangeoffroad.com/index...iy-h4hlrh.html
there is also a complete generic harness replacement, available from multiple places, ipf m002, for ~$85 or more:
http://www.lowrangeoffroad.com/index...g-harness.html
Old 06-13-2014, 05:38 PM
RAD4Runner's Avatar
OSV,
You're talking about the conversion harness? No need to be Toyota -specific. It will adapt to most any brand model with switched ground control similar to Toyota headlight circuit.
Yes, the conversion harness will route power directly from battery to its relay to headlight bulbs, then to fender ground near battery; over a couple of feet of thick wire, instead of the 15 or so feet of thin wire through the dimmer-combo switch of the stock circuit.
The amount of voltage drop (= power turned to heat in wire instead of light) you eliminate is dramatic
Voltage Drop Comparisons:
With Sealed Beam & Engine off
Stock Wiring
Low Beam:
Batt: 12.05V, Across low beam filament (pins 1 & 3): 11.15V
Voltage drop in wiring: 0.9V
volt drop = 7.5% of battery voltage
High Beam:
Batt 11.94, Across high beam filament (pins 2 & 3): 10.07
Volt drop: 15.7% of battery voltage!
After Retrofit (my retrofit is not even as GOOD as the harness):
Low Beam:
Batt: 12.31V, : Across low beam filament (pins 1 & 3): 12.11V
Volt Drop: 0.2 = 1.6% of Battery voltage
High Beam:
Batt: 12.24V, Across high beam filament (pins 2 & 3): 11.78V
Voltage drop: =0.46V = 3.75% of battery voltage
AustinTaco
08-22-2022 10:45 AM
Yota.Jay
03-06-2016 11:02 PM
bigblue82
10
07-06-2015 08:27 AM
streetuner15
06-18-2015 10:59 PM
Otay
British Columbia
06-17-2015 04:08 PM
Quick Reply: 84-85 Pickup and 4 Runner Headlight upgrade
