7 inch lift question.
I am wondering what the deal is when on the 7inch kits it says. You need to modify the steering arm to where the ball is pointing out of the top of the arm instead of down?
Here is a thread on the Pirate4x4 forum about this:
http://www.pirate4x4.com/forum/showt...+ball+steering
Below is a link to another thread in which I posted a photo of my steering arm with a Procomp 3" drop draglink. I had to go to the Procomp after installing an OME lift even though OME said that I could stay stock. Although the kit is supposed to be 2 1/2 inches +/-, I would say that it was closer to 4 in my case.
I tried to use the stock drag link by pressing out the draglink ball on the steering arm. We couldn't get it out and I didn't want to grind/weld, etc. and take a chance on it falling out at the wrong time.
For 7" I don't think the stock draglink will work even if you do flip the ball to the top. You need a drop draglink or go to hysteer.
https://www.yotatech.com/forums/f115...sement-124660/
7" leafs+3" body+(2"(longer then stock)shackles)/2=1"+ 3"drop hangers= 14"Lift.
Go with something closer to 4" Lift! You can fit as big of tires as you want(with fender trimming) and then you wont need an oxygen mask in the cab!
A 14" lifted Toyota is NOT a clean lifted truck!!
I say "good on you " seperate yourself from the "pack" .. your right .. different strokes .
I think to many guys hack em up and beat the crA p out of em , and just cuz they do , they want you to do it too , or else it's WRONG . oooooo buy this hi streer ... ooooo buy that hi steer .. all "pirate wanna bees "
I got no problem with a mall crawler .. I love em!
to each there own ...
