4:88 gears with 35 "
Old 01-01-2013, 03:34 PM
  #81
rokblok's Avatar
I will check in AM.
And the 4.88s only came as an option on some 4runners.
Old 01-01-2013, 03:37 PM
  #82
jaredvrose's Avatar
Ok so aparently i have a 9" rearend? I thought all toyotas have 8"?because only the 9" have 12 bolt holes on the ring but please do let me know what u find
Old 01-02-2013, 08:23 AM
  #83
rokblok's Avatar
Well, I lied. I must have left my 4.88 thirds in my storage in Ga. I apologize.
Can you post up pics of your third and the overall rear end? A 9" would mean somebody swapped it, because it didn't come with it, that's for sure.
Old 01-02-2013, 08:51 AM
  #84
jaredvrose's Avatar
Its not a 9" its actually a tacoma rear end i found out!lol tacomas have 12 bolt rings and pickups have 10. Any way you would sell any of those 4:88s?
Old 01-02-2013, 09:20 AM
  #85
rokblok's Avatar
I think you can find a factory 4.88 pretty easy. Like I said earlier, I found 3 in my local Pullapart. I only took 2 of the rear thirds, but it sounds like I shoulda snagged all 3.... Lol.
And I guess I could sell one, but for me to drive 5hrs back to my storage unit for that wouldn't be very cost effective for either of us. I live in Madison, Al now, so let me call around here and see what's available. Give me a couple hours..
Old 01-02-2013, 09:25 AM
  #86
jaredvrose's Avatar
Thanks! But dont look too hard lol
Old 01-02-2013, 09:31 AM
  #87
rokblok's Avatar
How far are you from Montgomery? The Pullapart there has three 4runners, one '95 just put out a few days ago. Birmingham Pullapart has 2 Runners. I'd be willing to bet one of them has a 4.88 rear.
Old 01-02-2013, 09:35 AM
  #88
jaredvrose's Avatar
Hmm idk quite a ways.it would probably be cheaper to reorder the right ring and pinion for a tacoma than drive there
Old 01-02-2013, 09:38 AM
  #89
rokblok's Avatar
If they will credit the R&P back that was wrong, I would do that. I'm gonna run over to a local yard here and see what they have. They don't have online inventory, so it's a "go and see" kinda thing.
Old 01-02-2013, 10:01 AM
  #90
jaredvrose's Avatar
Yeah this site is screwing me they are trying to make me pay the return after they said they would because there site doesn't give required info to determine which gears are correct. NEVER ORDER ANYTHING FROM ROCK AUTO!!theyre cheap but once u they mess up everything messes up
Old 01-02-2013, 11:37 AM
  #91
rokblok's Avatar
http://home.4x4wire.com/erik/diffs/
Let us know what you have.
Old 01-10-2013, 12:20 PM
  #92
jaredvrose's Avatar
Just got my right gears today now the problem is i have no way to reuse my pinion bearing because i cant get it off so i tried getting o riellys to order it because i need it now and the one they gave me was too small.i think it was the bearing that goes behind the flange not the one that presses all the way on the pinion.the bearing was for an "inner" pinion bearing.now please correct me if im wrong but isnt the inner bearing the one that you press all the way on the pinion?and the outer the one in the back of the chunk near the seal and flange?
Old 01-10-2013, 08:18 PM
  #93
rokblok's Avatar
Inner is the one closest to the gear teeth. Outer is the one closest to the driveshaft.
Old 01-10-2013, 08:25 PM
  #94
jaredvrose's Avatar
Yeah and i ordered the inner bearing and it was way to small so now im trying to save my old one with a bearing seperator because the guys at o riellys dont know jack. This is what they gave me
http://m.oreillyauto.com/mt/www.orei...3332&ppt=C0362
Old 01-10-2013, 08:51 PM
  #95
rokblok's Avatar
Ya know the master kit has the bearings you would need....
Old 01-10-2013, 08:53 PM
  #96
jaredvrose's Avatar
Yeah but i imagine thats over 100$ and just the bearing was 65$ and i need to be able to drive by sat
Old 01-10-2013, 09:02 PM
  #97
rokblok's Avatar
Let us know what you figure out.
Old 01-11-2013, 08:17 PM
  #98
1990-4runner's Avatar
Five speed 3.0 4runner 4" lift lots of weight with bumpers and more running 33-12.50's. any one disagree with 5.29 gearing not much highway driving mostly just getting to the trail hopefully I can do 60 on the highway if need be with out Erving to high? Thanks
Old 01-21-2013, 09:39 PM
  #99
jaredvrose's Avatar
If i had to do it over again id get the 5:29 because the 4:88s didnt cut it for me altho i have the a340h auto tranny but same setup as u.
Old 01-21-2013, 09:44 PM
  #100
Toyota~Boy's Avatar
I'm running 33/10.50r15's 22r 5 speed with 4.88's. I'd much rather have 5.29's. 4.88's are good but if you have a 500# trailer behind you then your back to downshifting on hills. But overall I guess the 4.88's are okay. I'm carbed as well and that's a big power difference between you EFI guys.
Quick Reply: 4:88 gears with 35 "
