3/4 ton brake master and rear disc question.
I'm about to replace my brake booster and master cylinder and was wondering if anyone knows how interchangable the different types are.My truck origionally had a dually rear end and I'm unable to find any difference in the brake system design between it and the regular setup. I found a 3/4 ton master cyl with a 7/8 in bore and would like to know if this on has any real difference from the LCE one inch bore other than the 1/8 in diameter difference. Also I want to find the best possible booster I can that will mount to an 84 fire wall. I'm considering doing a rear disc conversion later this year, so I'd like to head this off early. Any advice?
There's a couple swap kits that use your trucks front disc and calipers. So upgrade front to LC disc and IFS calipers then move your fronts to the rear. This plus the MC and dual diaphram updrades and you'll have much more braking than stock.
You'll need a parking brake solution though.
I believe it was a 99 Taco 2wd. It seems that all the masters I have seen while searching for my 3RZ, that were on later model(94 and up) were externally the same. Didnt seem to matter if the truck were 2wd or 4wd. The reason for this, I am guessing, is the 2wd trucks have 1 large diameter piston in their calipers(large volume of fluid needed to move the piston same as four smaller diameter pistons).
The reason I asked was because I did a little looking around and found ones with 2 or 4 hole patterns for mounting to the booster, and one of which was brand new on ebay for a penny and had a four hole pattern.
I bought my booster and one inch master cylinder, but the master cylinder didn't have any markins displaying which port is for front or rear. Can anyone point me in the right direction?
I know it has been a while since I posted on this, but I installed the booster and master cylinder. I'm looking at proportioning valves on JEGS.com right now hoping that will sort out the problem of my brakes doing nothing intil I'm nearly on the floor, then suddenly locking up. I was wondering if anyone has any suggestions for which valve to use. I was thinking of a simple knob type adjustable, JEGS brand. Also do I need to remove my Load sensing Proportioning valve when installing the adjustable one?
the master was bench bled before install correct? all 4 corners were also bled afterwards? adjusting the back shoes should help also if you're still running drums.
bench bled and all fours were also. My entire system was dry when I installed also, but I got all of the air out. I checked and bled a second time too.
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
