22r timing issue
Old 02-25-2010, 01:59 PM
noshine87's Avatar
22r timing issue
I need a little help on my 84 22r. I was checking my timing today with a timing light and found it was set at 0 degrees on the timing mark tab. So I loosened the distributor and there is no more adjustment on the distibrutor to get it to 5 degrees. I'm wondering if you can just pull the distibrutor out and move it back one tooth and try agin? Or is there something else I need to try? Any help will be grately appreciated.
Old 02-25-2010, 02:14 PM
Firefightertaco's Avatar
are you disconnecting your vacuum advance and plugging that up when you adjust your timing? and the spec for the 22r is 0 deg. tdc at max 950rpm anyways with the vac advance unplugged
Old 02-25-2010, 04:52 PM
noshine87's Avatar
Yes both vacuum lines disconnected and plugged. The sticker under hood says 5 deg. before tdc.
Old 02-25-2010, 07:13 PM
hmm idk, it said 0 deg in my Toyota service manual, but yeah i would just stick with the 5btdc, an yes you can pull the distributor out and spin it one tooth, it can be sorta tricky i can never get it right it takes me like 4 trys but i recommend taking off the cap and watch how far you spin the rotor button
Old 02-26-2010, 03:37 AM
noshine87's Avatar
Thanks Firefightertaco. I'll give it try today.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 22r timing issue
