1989 22re clicking timing chain, replacement?
Old 04-18-2014, 01:14 PM
AquaticFish69's Avatar
Hey ya'll, just noticed an interesting clicking noise under the hood. I was thinking it could be the timing chain guides? Sounds like a pen being clicked 1,000 mi/hr. It's my first 22re so I don't know if this is normal for this pickup. It's a 1989, 22re, 104,000 miles on the clock so I guess I might as well throw a new timing kit in. Also when i'm accelerating in 1st gear, theres a grumble noise, you can hear it in the video when I accelerate on the gas a little bit.
Take a look at the video, thanks for the interest.
Old 04-21-2014, 04:23 PM
slacker's Avatar
sounds more like an exhaust leak . Check your manifold for cracks as well as it may need to be resurfaced . or maybe one of the head studs is loose
Old 04-23-2014, 07:06 AM
I adjusted my valves to specs and that changed nothing. I found a little pin hole leak in the exhaust manifold and bolt missing. You think that's causing all the ruckus?
Old 04-23-2014, 07:17 AM
Inferno451's Avatar
Could very well be. It's very likely it's stripped out of the head. Very common on these aluminum heads.
Old 04-23-2014, 11:40 AM
Your right it is stripped, I tried to screw in the replacement bolt and it wouldn't bite. I'm hesitant to tap it, i've heard they can leak.
Old 04-24-2014, 02:20 AM
parchisi's Avatar
I imagine a helicoil is your friend in this case. Remove the header and old gasket, install the helicoil, new gasket and cinch her down.
Old 04-24-2014, 07:23 AM
Angry
Did all of that, still rattled. Did a little more diagnosing, and I found that it's the rod bearings I guess I caught right when it was starting because it's a very quiet knock. If the rod bearings are bad, I know it's probably time for a rebuild...What do you guys think, change rod bearings now and drive it for anther few k's or start rebuilding?
Old 04-24-2014, 12:52 PM
parchisi's Avatar
Does the noise go away under acceleration, but return when coasting on the engine? That's how mine acted when it had a rod bearing go bad.
I drove cross country with it that way about 1,000 miles and it did well, but I rebuilt it right after that. No reason to drive it 'til it expodes on you.
Old 04-24-2014, 02:24 PM
Yes, the noise goes a way when im coasting,also i can only hear the knock in gears 1-2....Did you pull the engine or just replace bearings?
Old 04-25-2014, 08:47 PM
I decided to replace the rod bearings and repare my leaky oil pan, but i can't seem to pull the differential. I have all the bolts pulled, cross member, drive shaft, mounting bolts, i just cant seem to get the bolts from the CV joint out. You can see in the picture I got the nuts off, but the nuts are still in there. How do I get them out?
Attached Thumbnails 1989 22re clicking timing chain, replacement?-img_0305.jpg   1989 22re clicking timing chain, replacement?-img_0306.jpg   1989 22re clicking timing chain, replacement?-img_0308.jpg
fasterspider
10-06-2015 10:24 AM
Ichneumon
09-27-2015 04:21 PM
hexrain
06-27-2015 06:17 AM
Taz22R
06-21-2015 04:44 PM
paxanders
06-21-2015 06:29 AM
Quick Reply: 1989 22re clicking timing chain, replacement?
