1985 22R won't run right when timing is right
Old 10-25-2011, 03:13 PM
dubyayoung's Avatar
I have to replace that whole unit?
Old 10-25-2011, 04:05 PM
xxxtreme22r's Avatar
I think I might have confused you when I said it's two-piece. It is 1 part You have to replace the entire thing. What you can do for the time being is make a mark that is even with the keyway and use that as your new timing indicator. But That pulley timing marked moved for a reason and it's most likely gonna happen again on that part if you don't replace it. After replacing it, I would double check the cam to crank timing again and make sure it's right. Then move the distributor accordingly like originally planned.
Old 10-26-2011, 07:34 AM
dubyayoung's Avatar
Here's the new one
Hopefully I will get this on today. I'll let you know how it works.
Note the timing mark is aligned with the keyway.
Old 10-26-2011, 03:09 PM
dubyayoung's Avatar
We have success!
I put the new balancer on, retimed the engine, and it runs great! Smoother that it has in a long time (apparently the balancer really does work)!
Thanks to all, but especially xxxtreme22r, and extra thanks to Smogman, who saw the problem clearly!
Old 10-30-2011, 01:42 PM
  #25
dubyayoung's Avatar
Follow up
If anyone is interested in how things turned out smog wise, I have started a follow up thread to go over the smog tests. It is called "22R Smog test woes (CA)"
83flatt
07-02-2015 10:30 AM
puddlepirate
06-30-2015 05:08 PM
newzingo
06-24-2015 01:50 PM
Eagle564
06-23-2015 11:29 PM
JaredL
06-16-2015 04:47 PM
Quick Reply: 1985 22R won't run right when timing is right
