1984 22r egr/vacuum line delete
only need 2 vacuum lines - one from the distributor (Normal/ported advance - the port closest to the radiator) to the carb and one from the distributor (Idle/Manifold advance - the port closest to the head) to the manifold. And you'll have a larger vacuum hose going to your manifold if you want to run the brake booster (recommended). Cap EVERYTHING else.
should look like mine:
I see that you have labeled yours "I" and "R" Great!!!! now I have an idea which is "fuel in" and "fuel return". I didn't have the luxury of labeling and removing mine, so now that I know which hard line is which, thanks to your pic!. I would like to know if you have a pic of the fuel tank hard lines just below where those are that you labeled, so I can hook mine up correctly
I would greatly appreciate it if you can help me out
thanks!!
I have been searching for hours on how to hook up the fuel hard lines under the intake of my 87 22r carbureted.
thanks!!
thanks!!
So what about all of the vacuum switches and choke opener on the carb? Block it off? My 22r is running good but it won't idle!! Missing the charcoal canister but I don't think that is needed?
Iceman4193
08-28-2015 08:43 PM
BK2TFUTURE
07-28-2015 10:01 AM
