Pre 84 Trucks 1st gen pickups
Yes U Can OME + HiSteer
Old 04-25-2011, 07:15 PM
SC81YOTA's Avatar
First gen truck with an OME lift and High Steer. I have the heavy duty spings (I have arb bumper and winch). I also used two driver side springs and a 3/8th's inch block on the drivers side. BUT I have also removed the bottum spring on both leaf packs to lower the truck and give it a better ride (my personal preference). Just thought Id share.
HighSteer004.jpg?t=1303787563
HighSteer001.jpg?t=1303787563
HighSteer002.jpg?t=1303787563
HighSteer003.jpg?t=1303787563
Old 04-25-2011, 07:18 PM
Fossilized
Staff
dropzone's Avatar
very cool...
looks like a flat pitman arm has been tweeked slightly
with the spring removal approximately how much lift did you end up with?
Old 04-25-2011, 07:27 PM
SC81YOTA's Avatar
Yea and it took a press to bend that thing (had to do it to clearance the frame and oil pan). I could of done a better job positioning the steering box but this was my first go round and you learn as you live. Special No thanks to my brother and my mechanic for watching me start this project and walking out the shop door with no help. No respect after five o'clock thats for sure. lol!
Old 04-25-2011, 07:29 PM
Fossilized
Staff
dropzone's Avatar
my steering box placement isn't perfect either,first never is so I can relate
curious about your ARB bumper-stock 1st Gen or did you mod one a 2nd gen?
Old 04-25-2011, 07:47 PM
waskillywabbit's Avatar
Barney was OME and High Steer
https://www.yotatech.com/forums/f198...barney-188749/
:wabbit2:
Old 04-25-2011, 07:50 PM
4x4YOTA's Avatar
what size tire are you running and what is your frame to ground measurement?
Old 04-25-2011, 09:34 PM
SC81YOTA's Avatar
ToyotaPics001.jpg?t=1303794954
This is the way my truck sits now on 32's. I could clear 33's but I do most of my wheelin in the southern apps. mountains. Mostly steep dirt hills with no turn arounds at the end of the trails so I prefer to keep it low and locked. I have not measured my chassis clearance but in my situations I have never been hung up. It seems like im always teetering on two wheels, and most of the time I dont like it. BUT who never tried, Never Did.
Old 04-25-2011, 09:41 PM
scuba's Avatar
Beautiful truck! Looks awesome!
Old 04-25-2011, 09:50 PM
camo31_10.50's Avatar
definitely in the top 5 of most beautiful lookin 1st gens lol
Old 04-25-2011, 10:49 PM
SC81YOTA's Avatar
Not sure. It came with a old school 3" superlift 3" kit and I have been trying to lower it ever since. It road to rough plus my back tires kept coming off the ground. Only option left for me is to get a skyjacker kit and start pulling leafs. They seem to ride the best plus flex alot. OME is to stiff for me in my experience.
Old 04-26-2011, 01:25 AM
xxxtreme22r's Avatar
SC81YOTA love the truck, what color is that?
Old 04-26-2011, 07:31 PM
Jeffp's Avatar
Love thr truck. Where did you get the soft topper? Trying to find one for my longbed.
Old 04-26-2011, 10:16 PM
SCToy's Avatar
Did you have reposition the spring and shackle hangers?
Old 04-29-2011, 12:29 PM
SC81YOTA's Avatar
xxxtreme22r im not sure of the color. They guy that restored the truck worked as a mechanic for toyota so I assume it is a toyota color but not sure if he went back with the original color or something like a landcruiser color or something.
Jeffp go to softtopper.com and buy one for an 89 to 94 truck. It should fit perfect. Also you will have to dril a hole in the bed rail and the softopper rails and bolt it to the bed. I used two bolts per side. (We cant use bed clamps with first gen beds)
SCToy to answer your question, No. It is all stock placement.
Old 04-29-2011, 01:04 PM
Sensei's Avatar
Very clean lookin truck. Nice job. Doesn't look like you plated your frame when you installed the steering box. Am I missing something in the photo ?
Old 04-29-2011, 02:04 PM
SCToy's Avatar
Thanks for all the info. Great looking truck
Old 04-29-2011, 02:30 PM
1stGenBen's Avatar
Just repainted my '82 the same color. Factory toyota beige. color code 4A8. keeping it orignal! oh, the pic of your truck is now the background on my desktop. keeps me on track for my build.
Old 05-03-2011, 02:34 PM
SC81YOTA's Avatar
Yes I plated the frame. It was a complete kit.
THANKS FOR ALL THE COMPLIMENTS GUYS.
Now I am redoing the interior. Ill start a new thread in the build up section soon.
Old 09-20-2011, 03:18 PM
scheefdog's Avatar
I am in the process of installing high steer on my truck and wanted to post a few pics of it mocked up to make sure I've got the IFS box in the right spot before I started drilling and welding. I just installed OME medium springs with 5" shackles and will post a writeup when I get the whole thing done because there seems to be a lot of questions about OME.
Everything I've read is get the box as far forward and as high as possible (but I realize most people move the axle forward). However, should the drag link and tie rod be parallel (viewed from the side of the truck)? That is how I have it positioned now, with the box as high as it will go and clear the frame. I realize I will have to put longer bumpstops on to limit the up travel to when the spring gets flat.
The following users liked this post:
SMG (09-22-2020)
Old 09-20-2011, 03:54 PM
SCToy's Avatar
I wish I had spent more time experimenting with my box position. One of these days I will go back and redo it. I would move it as far forward as you can squeeze it and get the pitman arm as close to the frame as you can. Check that the spring doesnt hit the pitman arm on compression.
Quick Reply: Yes U Can OME + HiSteer
