Pre 84 Trucks 1st gen pickups
Will a 91 22re starter fit in an 84 22r???
Old 02-24-2010, 06:02 PM
toyospearo's Avatar
I swear I did a pretty thorough search and I couldn't find this answer.
I was at the JY today browsing through the 1st, 2nd and 3rd gen 22r and 22re series and I noticed a 91 with a shiny new starter. Tomorrow I plan on pulling it and putting it in my buddies 84. I need to know if it will work.
Thanks
Old 02-24-2010, 06:06 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Yes.
And just so you know, there is no aftermarket starter that's better than the OEM one, and IF one ever develops problems it's usually $5 brass contacts... that you should get from the dealer... Or Rodger Brown.
Old 02-24-2010, 06:09 PM
All 22R starters are the same.
And the V6 starter will have threads where a bolt goes from the back of the BH into the starter. One stud, one hole is threaded... None of the 22R holes are threaded.
Old 02-24-2010, 06:22 PM
toyospearo's Avatar
This starter I found was in a 91 22re. I got all ginned up to pull it and put it in my buddies 84 that is why I started this thread.
Thanks for the reply's!
I agree there is no better starter than the OEM. This 84 4x4 had the original OEM starter in it. It had finally failed after 26 years of faithful service!
The shiny new starter I saw in the 91 was none other than a Bosch but hey, what can you do?
Old 02-24-2010, 07:11 PM
Outsane's Avatar
You may need to get a new Alt bracket...
Plug for the alt..
and Delete the external voltage regulator from the fenderwall..
atleast I did...
https://www.yotatech.com/forums/f115...ed-out-202693/
Old 02-24-2010, 07:33 PM
Outsane's Avatar
Old 02-24-2010, 08:58 PM
Pumpkinyota's Avatar
Plug for the alt..
atleast I did...
For a starter? What am I missing here?
Old 02-25-2010, 06:35 AM
Outsane's Avatar
nothing.. I just have alternator on my brain...
don't mind me..
Old 02-25-2010, 08:26 AM
don't mind me..
Although, thanks, the plug diagram could be useful to me right now =P
Old 11-09-2016, 07:59 PM
tuppz's Avatar
on Ebay I found a starter rebuild kit just wondering if its worth my $6 haha
sandyota
02-04-2021 11:16 AM
redneck17
10-29-2015 09:09 PM
ZONAYODA
07-13-2015 07:17 PM
cars-guy
07-11-2015 07:51 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Will a 91 22re starter fit in an 84 22r???
